Old 09-19-2003, 10:53 AM
poolshark poolshark is offline
Talking walkTo function
Is there a substiture for the walkTo function from the earlier version because it doesn't seem to work in the new version 2.09
Old 09-19-2003, 11:01 AM
There should be an example of the walkTo function in the following tutorial in the Start Menu , "Vizard20 -> Tutorials -> Avatars -> R1 Single". Run this example and after it has started press 'w' to add a walk action to its action queue then press 'g' to get the avatar going. Let me know if this doesn't work.
Old 10-09-2003, 01:13 PM
R1 Single?
I didn't find this script in the place that you suggested
Old 10-09-2003, 01:36 PM
Are you sure you are looking in the Start Menu and not the actual directory? The example I mentioned above links to the following file:
C:\Program Files\Vizard20\tutorial\avatar\tutorial_1.py
If it's not there then maybe you chose not to install the example files when you installed Vizard.
Old 10-09-2003, 01:45 PM
that one i have seen. that's sort of what i assumed but that didn't deal with Cal3d Avatars just the built in avatars. that's fine, I posted another message about using the Cal3D.py file.
