Old 04-19-2021, 12:07 PM
JoeyB JoeyB is offline
Registered User
Remove disparity (same display in two eyes) in HMD
Goal: I'm trying to remove binocular disparity in HMD for an experiment on human vision. In other words, I need to project two identical displays to two eyes as they come from one camera.
Specs: I'm using Samsung Odyssey HMD. My experiment code is written in Python on Vizard IDE. There is a "steamvr" package in Vizard, which I use to create a <hmd> object to interface with HMD. The machine I'm using is MSI VR ONE with a 1070 graphic card.
Solution tried: I tried using "hmd.setIPD(0)" but the IPD (interpupillary distance) is always overwritten by the physical wheel on the HMD that adjusts the distance between two lenses.
Is there any other way I should try? Can I change some
Old 08-25-2021, 10:07 AM
mspusch mspusch is offline
Hi JoeyB,
I believe you got this solved with some help from our engineers in the closed support forum - would you mind posting the solution here as well for other researchers to learn from?
Thanks a lot,
Matthias
binocular disparity, samsung odyssey, steamvr
Duplicate HMD display on primary monitor, with eyetracking info performlabrit Vizard 3 09-19-2014 10:44 AM
Eyes that keep looking at the mirror Frank Verberne Vizard 3 05-13-2008 05:39 AM
Heads with geometries for eyes and mouth Karla Vizard 2 03-14-2008 11:39 AM
