Old 08-03-2020, 12:56 PM
F_Rocabado F_Rocabado is offline
Unhappy Problems saving my data
Hello everyone,
I've been working for a while now on the script I'm going to share down below. I have struggled a making my data iterable type so I could save it but now I don't know why it only saves the last trial data. All my experience with python comes by working on this script... any help will be very much appreciated it since I've been all day trying to figure out why this is happening with no luck
import viztask
import vizinfo
import vizshape
import vizfx
import vizcam
import random
viz.setMultiSample(4)
viz.fov(60)
viz.MainView.move([-9,40,60])
#luz
light = viz.addLight(euler=(90, 89, 90))
light.position(1,1,1,0)
light.color(viz.WHITE)
light.ambient([1,1,1])
light.intensity(1)
light.spread(180)
viz.setOption('viz.lightModel.ambient',[0]*3)
#Clase
viz.clearcolor( viz.SLATE )
classroom = viz.add('classroom.osgb')
# cielo
classroom.getChild('pz_skydome').remove()
day = viz.add('sky_day.osgb')
day.renderToBackground()
# e_neutro
neutro = vizshape.addSphere(radius=5)
neutro.color(viz.WHITE)
neutro.setPosition([-4,60,150])
neutro.visible(False)
# Añadimos los objetos de la tarea
duck_der = viz.addChild('duck.wrl', parent = classroom)
duck_der.setPosition(13,55,150)
duck_der.setScale([15,15,15])
duck_der.visible(viz.OFF)
duck_izq = viz.addChild('duck.wrl', parent = classroom)
duck_izq.setPosition(-21,55,150)
duck_izq.setScale([15,15,15])
duck_izq.visible(viz.OFF)
wheelbarrow_der = viz.addChild('wheelbarrow.ive', parent = classroom)
wheelbarrow_der.setPosition(13,55,150)
wheelbarrow_der.setScale([15,15,15])
wheelbarrow_der.visible(viz.OFF)
wheelbarrow_izq = viz.addChild('wheelbarrow.ive', parent = classroom)
wheelbarrow_izq.setPosition(-21,55,150)
wheelbarrow_izq.setScale([15,15,15])
wheelbarrow_izq.visible(viz.OFF)
def despedida():
	fin = vizinfo.InfoPanel('Has terminado con el experimento')
	fin.visible(viz.ON)
	yield viztask.waitTime(3)
	fin.visible(viz.OFF)
results = []
obj = [duck_der, duck_izq, wheelbarrow_der, wheelbarrow_izq]
def Trial():
	neutro.visible(viz.ON)
	yield viztask.waitTime(0.65)
	neutro.visible(viz.OFF)
	for i in obj:
		print(1)
		object_d = random.choice(obj)
		object_d.visible(viz.ON)
		d = yield viztask.waitDraw()
		#prueba de que va bien
		print 'obj name:', object_d
		#Tiempo desde que aparece el objeto en la pantalla
		displayTime = d.time
		#Teclas de ineterés
		d = yield viztask.waitKeyDown(('f', 'j'))
		#Calculamos el tiempo de reacción
		reactionTime = d.time - displayTime
		p_key = d.key
		#Prueba de que el tiempo de reaccion es correcto
		print 'Reaction time:',reactionTime
		print 'key:',p_key
		#Apagamso los objetos
		results.append((object_d, p_key,reactionTime))
		#Tiempo de espera entre ensayos
		yield viztask.waitTime(1)
		#resultados
	viztask.returnValue(results)
def Experiment():
	yield Trial()
	yield despedida()
	#Log trials to file
	try:
		with open('Data.txt','w') as f:
			for object_d, p_key,reactionTime in results:
				data = (str(object_d)+'\t'+ str (p_key)+'\t'+ str(reactionTime)+'\n')
				f.write(data)
				print out
	except IOError:
		viz.logWarn('Could not log results to file. Make sure you have permission to write to folder')
viztask.schedule( Experiment() )
Old 08-25-2021, 10:45 AM
mspusch mspusch is offline
Hi Rocabado,
Hope all is well. We are just working thru a clean-up here with our support systems and from what we can tell, your support ended up happening in the WorldViz closed support ticket system for our customers with Support contracts (under support@worldviz.com), and hopefully your questions have all been addressed?
Sorry for not answering earlier here, and thanks for being a Worldviz customer.
All best,
Matthias
data, experiment, task
Vizard and Matlab sagar29 Vizard 7 12-25-2017 11:36 PM
Sending data from MATLAB(Simulink) to Vizard sagar29 Vizard 0 01-05-2017 04:31 PM
Any experience with Polaris Spectra? VRPN is providing bad data! performlabrit Vizard 0 06-29-2016 03:19 PM
Use saved text file data as replay sources problem mizutani_jun Vizard 4 10-14-2010 05:49 PM
