Old 02-01-2019, 05:25 PM
fivel_lab fivel_lab is offline
autocomplete for custom module?
OK, so simple question but can't seem to find much help on the subject: is there a way to use the IDE's autocomplete for a custom module? The lab has a bunch of very commonly used utility functions and we have new people writing scripts every academic year. Would be very handy to be able to have autocomplete to facilitate training!
Old 02-03-2019, 05:39 AM
After importing the module into your script, the autocomplete should display the function names. Is the module in the same folder as the script or a different location?
Old 02-04-2019, 10:28 AM
Thanks! So, after your comment I confirmed that it works if the module is in the current directory of the script I'm working on. Very cool!
But, as you suspected, I have it setup as a package in a different directory (including __init__.py). I have added the path to the enclosing folder with sys.path.insert, but it still doesn't work.. ?
Old 02-05-2019, 05:58 AM
Can you post the code you are using to import the file including any path related commands?
Old 02-06-2019, 09:55 AM
Sure!
Directory structure is set up like this:
FIVEL/                       top-level enclosing folder
          fvl/                        package
              __init__.py                     package initalization
              likertScaleObj.py                  example package module(s)
          VRproject/                         project directory
              F18/
                    F18.py                    last semester's version of the exp
              S19/
                   S19.py                    current semester's version
the code in S19.py ::::
import sys
import os
import os.path as path
sys.path.insert(0, path.dirname(path.dirname(path.dirname(__file__))))
#confirm path info with print statements
print path.dirname(__file__)
print path.dirname(path.dirname(__file__))
print path.dirname(path.dirname(path.dirname(__file__)))
print sys.path
print os.listdir(path.dirname(path.dirname(path.dirname(__file__))))
import fvl #no error
but.. after that no magic autocomplete
thanks!
Old 02-15-2019, 08:47 PM
It does not look like the autocomplete is set to work with paths added on the fly using the sys.path.insert command. It may work by adding to the PYTHONPATH environment variable.
If the module is in a directory above you could use the following code to import the module. I just tested and this worked for me with the autocomplete:
# import module in directory above
from .. import my_module
# import module two directories above
from ... import my_module
Old 02-18-2019, 12:15 PM
oops just kidding.. the workaround code makes autocomplete work(ish) but throws an error on execution
ValueError: Attempted relative import in non-package
view_coliision module bbb Vizard 2 08-24-2016 12:46 AM
Could not locate _Vizcore module Bhavesh Vizard 1 06-21-2016 01:48 AM
vizinput module missing whaleeee Vizard 1 02-05-2013 11:30 PM
Exception in module vizjoy fordprefect Vizard 2 12-03-2012 01:41 AM
vhil module vadrian Vizard 2 01-27-2005 11:52 AM
