Old 12-05-2018, 05:13 AM
Vishav Vishav is offline
How to call same function 50 times and every time new value need to save?
Hi
My environment has an avatar.
Avatar randomly points to objects placed in left or right (target object) in one trial.
I have total 48 targets i.e. 48 trials having with two objects one target and one distractor.
I have fixed function for left and right pointing but every time any two only objects should ON from 48 objects.
How I can easily write concisely?
Old 12-05-2018, 08:44 PM
Add all the targets to a list. For each trial use the random module to select two values between 1-48. Then turn on the visibility of the two targets in the list with matching indices.
Old 12-06-2018, 10:05 PM
That is the issue. How to make list of all 50 objects with fixed position and how to call it by indices?
Old 12-07-2018, 12:56 AM
For example I have 8 objects. My Code:
ob1=viz.add('D:\PhD\S_Study\Objects 3D\Radio.dae',pos=[-0.9,0.38,2.54],euler=[0,0,0],scale =(0.014,0.014,0.0045))
ob2=viz.add('D:\PhD\S_Study\Objects 3D\Helmet.dae',pos=[7.75,1.38,-5.3],euler=[0,0,0],scale =(0.9,0.9,0.9))
ob3=viz.add('D:\PhD\S_Study\Objects 3D\Thomas.dae',pos=[-0.4,0.55,2.2],euler=[0,0,0],scale =(0.015,0.0135,0.009))
ob4=viz.add('D:\PhD\S_Study\Objects 3D\Picture.dae',pos=[1.1,0.64,2.3],euler=[90,0,0],scale =(0.3,0.3,0.3))
ob5=viz.add('D:\PhD\S_Study\Objects 3D\Bottle.dae',pos=[0.9,0.5,2.2],euler=[0,0,0],scale =(1.7,1.7,1.7))
ob6=viz.add('D:\PhD\S_Study\Objects 3D\Laptop.dae',pos=[-0.25,0.4,2.82],euler=[0,0,0],scale =(0.0018,0.0018,0.0017))
ob7=viz.add('D:\PhD\S_Study\Objects 3D\Spoon.dae',pos=[-1.25,0.08,5.75],euler=[0,0,0],scale =(0.031,0.032,0.032))
ob8=viz.add('D:\PhD\S_Study\Objects 3D\Chain.dae',pos=[1.3,0.55,2.5],euler=[0,0,0],scale =(0.7,0.7,0.7))
ob1.visible(viz.OFF)
ob2.visible(viz.OFF)
ob3.visible(viz.OFF)
ob4.visible(viz.OFF)
ob5.visible(viz.OFF)
ob6.visible(viz.OFF)
ob7.visible(viz.OFF)
ob8.visible(viz.OFF)
I put all in list:
my_list=[ob1,ob2,ob3,ob4,ob5,ob6,ob7,ob8]
Now I want to ON two at a time (ob1 and ob2) (one target and one distractor)
For next trial I want ob3 and ob4 to be ON and so on....
Old 12-07-2018, 08:53 PM
This is sorted...Thanks for valuable suggestions.
