Old 11-03-2017, 07:48 AM
VizMars VizMars is offline
check if fixation is on target
I want to check whether a (gaze) fixation (i.e. a position) is on an object or not in a 3d and a 2d scenario. I think I need the corresponding object coordinates to do this.
What is the best way to get not only the 3d position of an object and it's corresponding 2d screen coordinates but also the coordinates of the space that this object occupies in 3d and 2d?
Old 11-14-2017, 11:20 PM
Use the viz.pick command and pass in a screen position to determine the object that intersects it. This example script maybe helpful.
Post-hoc fixation detection from a noisy eye-tracker signal. performlabrit Vizard 3 11-15-2017 03:58 AM
how to check if specified number of targets are in proximity sensor? Vaquero Vizard 8 12-27-2016 06:23 PM
How to set the viewpoint as the proximity target in a Vizconnect configuration? jizh1000 Vizard 1 06-01-2015 12:18 PM
vizproximity hint - debug 2D areas related to a source only after adding a target! fordprefect Vizard 1 12-15-2014 01:37 PM
