Old 03-06-2017, 07:47 PM
cmitchel cmitchel is offline
Registered User
Displaying vizinfo messages on Oculus Rift
I set up a system a while ago with several messages. Some are toggled on / off when certain keys are pressed and others change their content when certain keys are pressed.
The messages are displayed using vizinfo.add('').
I now want these same messages to be shown on my Oculus Rift display (it doesn't matter if they are still on the monitor or not) but I can't find a good way to change the window these messages are displayed in. I also tried to create a canvas but this doesn't seem to work either.
Things do display if I do vizinfo.InfoPanel but I would rather leave it as is with the vizinfo.add('') if at all possible.
Any advice would be much appreciated about how to display messages created using vizinfo.add() onto the Oculus Rift.
Thanks in advance!
Old 03-06-2017, 11:32 PM
Objects rendered to the screen will not appear in the Oculus. The GUI canvas makes it possible to render GUI elements and some GUI containers in the world but fixed to the viewpoint. The vizinfo.InfoPanel works with the canvas, while the older vizinfo.add() object does not.
Old 03-10-2017, 09:14 AM
Registered User
Thanks Jeff - that works for adding one message to the canvas. But I am trying to add multiple messages to the screen independently (toggling on / off at different times and changing text depending on user key strokes). I was wondering if you had any advice about how to do this? Thanks again!
Old 03-13-2017, 04:03 AM
You could add multiple text objects to a panel and change them individually:
import vizinfo
panel = vizinfo.InfoPanel('Message panel')
panel.addSeparator()
text1 = panel.addItem(viz.addText('message 1'))
text2 = panel.addItem(viz.addText('message 2'))
text3 = panel.addItem(viz.addText('message 3'))
vizact.onkeydown(' ',text2.message,'new message')
Oculus Rift + Vizard help required sukhpreet Vizard 1 01-03-2017 11:52 AM
Displaying a Subwindow in Oculus Rift DoeVenture Vizard 4 08-02-2016 06:57 AM
Oculus Rift Drift teklab Vizard 20 04-01-2016 08:57 AM
Multiple post-process effects with oculus rift lklab Vizard 2 03-13-2015 02:48 PM
Displaying screen text in 3D (Oculus Rift) pjayaram Vizard 2 05-27-2014 09:06 PM
