Old 01-10-2017, 06:01 PM
nom nom nom nom is offline
vizconnect avatar manipulation
I'm trying to manipulate an avatar after I added it through vizconnect, but I have few questions that I cannot solve by myself.
First question is to change its orientation. I tried to directly modify the vizconnect script.
_name = 'male_2'
	if vizconnect.isPendingInit('avatar', _name, initFlag, initList):
		#VC: init the raw object
		if initFlag&vizconnect.INIT_RAW:
			#VC: create the raw object
			avatar = viz.add('vcc_male2.cfg')
			avatar.setEuler(90,0,0)
			avatar._bodyPartDict = {}
			avatar._handModelDict = {}
			rawAvatar[_name] = avatar
but it didn't do anything. Though when I print the euler, it shows the right euler values. So I tried to call it in my script.
Avatar = vizconnect.getAvatar('male_2').getRaw()
Avatar.setEuler(90,0,0)
print Avatar.getEuler()
This also didn't do anything while the euler value's correct when I printed.
Second question is that I'd like to make the head of the avatar invisible, so I tried the following code.
Avatar_head = Avatar.getBone('Bip01 head')
Avatar_head.setVisible(viz.OFF)
This gives an error:
** ERROR: Bone with name 'Bip01 head' does not exist
File "<string>", line 11, in <module>
File "C:\Users\User\Downloads\VR\Vizard script\Learning_PD_Day1_1.py", line 29, in <module>
AttributeError: 'VizBone' object has no attribute 'setVisible'
So i guess there is no bone object if I add an avatar through vizconnect.. or is there other way to grab it?
Thanks in advance!
Old 01-11-2017, 11:54 AM
Have you mapped any tracking data to the avatar through the animator in vizconnect? If so, then the tracking data may override the set command. You could:
  • Add a transport or group tracker above the avatar in the scenegraph and apply a 90 degree rotation to that.
  • Apply a 90 degree offset to the head tracking data.
Try the following to hide the avatar's head:
avatar.visible(0,'male_head.crfx')
Old 02-08-2017, 11:29 AM
Thanks for the reply and sorry for my late reply I finally had some time to try that and your first solution indeed worked, but the problem was that because the group tracker is a parent of the tracking data, when I rotated the avatar, tracking data from other input source also rotate, which overall the result was the same.
Though, I found a solution which I rotated the torso of the avatar to my desired direction and it worked greatly!
For the second part, I tried that code, but the following error message is shown.
** WARNING: Could not find subchild with name: 'male_head.crfx'
Is the name you provided correct?
Thanks in advance!
Old 02-10-2017, 02:44 PM
The following works for me using the male_2 avatar from vizconnect:
avatar = vizconnect.getAvatar('male_2').getRaw()
vizconnect optotrak sensors to avatar shashkes Vizard 8 03-14-2016 07:26 AM
Unexpected Avatar lookAt() behavior when using yield statements chris2307 Vizard 2 12-17-2013 02:58 AM
Collision of an avatar with a quad Frank Verberne Vizard 8 06-04-2008 09:44 AM
Looking through the eyes of an avatar Frank Verberne Vizard 2 04-01-2008 05:52 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 08:48 AM
