Old 11-21-2016, 03:32 AM
jelly jelly is offline
delaying proximity reaction makes sensor unresponsive for the time of delay
In a recent post I had a problem implementing a delay in the proximity manager and Jeff has suggested the solution of using "vizproximity.waitEnter" and a while loop:
def proximityTask():
        global handstate
	while True:
		yield vizproximity.waitEnter(SensorIndexFinger)
		print 'entered sensor'
		yield viztask.waitTime(2)
		print 'two seconds elapsed'
                handstate = 1
viztask.schedule(proximityTask())
However, with this code I have a new problem and I decided to open up a new thread:
What happens now is that, once the sensor is entered, the action (change of the variable handstate from 0 to 1), will be delayed by two seconds. However if I happen to enter the sensor again very quickly, before these two 2 seconds have elapsed, nothing happens, as it seems that it is not registered that the sensor has been entered, until the first action takes place.
I wonder if there is a way around this? I tried to to the following: I will change a new variable upon entry but then I will make a new function where I say that IF the new variable "condition" is equal to 1 then after 2 seconds the handstate should change to 1 (= delayed action). This way I am hoping that I am not delaying the action itself in the proximity manager, I am delaying it outside of that function so that the proximity manager can freely register all entries.
def EnterProximity_IndexFinger(e): # decide what happens on sensor entry
	global handstate, condition
	e.sensor == SensorIndexFinger
	condition = 1
	print condition
manager.onEnter(SensorIndexFinger,EnterProximity_IndexFinger)
with this I am just changing the variable condition and the I will try to use that in the following way:
def Handdelay():
	print "now"
	if condition == 1:
		#yield vizproximity.waitEnter(SensorIndexFinger)
		handstate = 1
		print "open hand"
		handstate = 0
viztask.schedule(Handdelay())
Unfortunately, the condition change is registered as soon as I enter the sensor, but the function which is supposed to call the delayed action (handstate changing to 1) is not working.
I would be very grateful for help!
Old 11-21-2016, 11:22 AM
It sounds like you need to determine whether the sensor was exited before two seconds elapsed. If that's the case, use the viztask.waitAny command to help with this:
	waitEnter = vizproximity.waitEnter(SensorIndexFinger)
	waitExit = vizproximity.waitExit(SensorIndexFinger)
	waitTime = viztask.waitTime(2)
	while True:
		yield waitEnter
		d = yield viztask.waitAny( [ waitExit, waitTime ] )
		if d.condition is waitExit:
			print 'Sensor exited before two seconds'
			print '2 seconds elapsed'
Old 11-22-2016, 10:02 AM
I have tried this code but what it does is, it triggers the action as long as the sensor is still entered, after 2 seconds and does not do that if the sensor is exited before 2 seconds have elapsed.
I actually think this might be a different issue:
I want an action to be triggered with a delay, every single time a sensor is entered. If I use waitEnter and waitTime what I achieve is that I "block" the sensor - nothing is registered until the action (and the 2 second delay) are carried out. So it cannot be that I trigger the action EVERY time a sensor is entered, because the 2 second delay creates a minimum of time that needs to have passed before another sensor entry is even registered. Basically, I want the sensor to be entered instantly, each time, and only the action - which is a consequence of the sensor entry - should be triggered with a delay.
Another illustration:
1) If I approach an object, I enter its sensor and I trigger an action of that object.
2) If I want a 2 second delay: I approach an object, I enter its sensor and I trigger an action of that object only after 2 seconds.
3) The problem comes now: If I approach an object a second time within one second of the first time, nothing will happen, because the program is still carrying out the action with delay scheduled as a response to the first approach.
Old 11-22-2016, 11:07 AM
Try the following example. After the sensor enter event occurs in the proximity task another task is called that handles the delay:
import vizproximity
import viztask
#Create proximity manager
manager.setDebug(viz.ON)
#Add main viewpoint as proximity target
target = vizproximity.Target(viz.MainView)
manager.addTarget(target)
#Create sensor using static matrix
sensor = vizproximity.Sensor(vizproximity.Sphere(1.0),source=viz.Matrix.translate(0,1.5,3))
manager.addSensor(sensor)
def delayTask():
	while True:
		yield vizproximity.waitEnter(sensor)
		viztask.schedule(delayTask())
Old 11-23-2016, 04:20 AM
Smile
Jeff, thank you very much! It works perfectly, I have adapted it for my script:
def delayTask():
	global handstate
	handstate = 1
	yield viztask.waitTime(0.7)
	handstate = 0
	while True:
I think I had a good intuition that I needed two steps or two functions to implement this, but I was stuck thinking that I needed the "manager.onEnter". Thanks again!
proximity, proximity sensor, timing
Proximity Manager - How to implement delay jelly Vizard 4 11-18-2016 08:48 AM
