Old 10-03-2016, 03:32 AM
zumbay zumbay is offline
Return distance covered by the viewpoint
I am quite new to Vizard and thus far things have gone quite smoothly, but now I seem to be stuck at something which I couldn't find an answer to!
Is there a straight forward way of returning the distance a "player" has covered between two events/objects? Basically tracking how many meters were passed by the viewpoint? Something like:
start tracking
end tracking
return distance covered
I was searching quite a lot in the documentation/forum, but I am probably not using the proper keywords or terminology.
Thanks!
Old 10-03-2016, 06:17 AM
You can get the distance between any two points using the vizmat.Distance command. To calculate the total distance covered you could register a function with vizact.ontimer that calculates distance over small time intervals and add those up.
Old 10-06-2016, 03:42 AM
thanks Jeff! worked the way you suggested!
distance, viewpoint
Regarding Viconnect viewpoint rajnishv Precision Position Tracker (PPT) 3 03-20-2017 11:03 PM
purpose of distance parameter in setRenderWorldOverlay dcnieho Vizard 2 09-10-2016 05:27 AM
Regarding viewpoint with vizconfig,addFloatRangeItem&Storing viewpoint in PREFERENCES rajnishv Vizard 0 06-27-2016 03:57 AM
Intermittent orthographic stereo projection problems AySz88 Vizard 10 02-17-2012 12:50 PM
