Old 09-09-2016, 04:12 PM
biomech_dave biomech_dave is offline
Registered User
Controller Coordinates and Euler angles
Hello! I'm using the Vive for proprioceptive reseach and need to get the coordinates of the controllers. I am new to Python but I tried manipulating the steamvr example like this:
import vizshape
import steamvr
for controller in steamvr.getControllerList():
print "connected"
total = 0
if total == 0:
left_controller = controller
total += 1
right_controller = controller
print right_controller.getPosition()
I get an error that 'right_controller' is not defines. I'd like to get the Euler angle and position output continuously while the programming is running. Any thoughts would be helpful.
Thanks!
Dave
Old 09-10-2016, 02:09 AM
If both controllers are connected, try the following:
rightController = steamvr.getControllerList()[0]
leftController = steamvr.getControllerList()[1]
def printData():
	print 'pos right:',rightController.getPosition()
	print 'pos left :',leftController.getPosition()
vizact.onupdate(0,printData)
However, I would recommend using vizconnect to connect to the Vive in Vizard. In the preset configuration list there is a 'HTC Vive' option. That connects to all hardware and renders a hand for each controller. The transport allows you to navigate using the controller track pad. You can also get the controller position in your own script:
rightTracker = vizconnect.getTracker('r_hand_tracker').getRaw()
leftTracker = vizconnect.getTracker('l_hand_tracker').getRaw()
def printData():
	print 'pos right:',rightTracker.getPosition()
	print 'pos left :',leftTracker.getPosition()
Old 09-12-2016, 04:25 PM
Registered User
Great! That helped a lot! I also have the code for the module generated by vizconnect which will help.
Thanks again for the really quick reply.
Cheers,
Oculus Rift Drift teklab Vizard 20 04-01-2016 07:57 AM
How to keep the Orientation of mainview same as the world coordinates in the vizard jacky Vizard 1 05-17-2013 12:01 PM
display the position and euler coords of the main view Josh Vizard 1 03-22-2010 10:48 AM
Dtrack and avatar -coordinates question sircedric4 Vizard 3 09-08-2009 11:32 AM
