Old 10-20-2009, 05:24 PM
Green Green is offline
Smile Can I load 7 people avatars with different identities into vizard?
I know that there are a male and a female avatars in the resources folder provided by vizard program. But, right now I want to load 7 avatars into the vizard virtual environment. How can I do that? Is there any additional resources that allow me to achieve my goal?
Thanks!
Old 10-22-2009, 08:37 PM
billjarrold billjarrold is offline
There is a section in the user manual called "Built In Avatars" that says that Vizard comes with 4 pre-build avatars. So, if you want 7 but don't mind some of them being clones of each other you can do that.
If you want 7 avatars that all look different, then one thing you can do is buy "Complete Characters". It comes with a bunch (maybe 50? I forget exactly). Each of them have on the order of 30 pre-existing animations as opposed to the 10 or so you get pre-existing inside every Vizard.
Are there other ways of making your own avatars? There must be but I'm too much a newbie to know.
Vizard tech tip: Blinking Avatars Jeff Vizard 3 11-24-2009 01:16 PM
problem with exporting avatars and using them in Vizard VDong Vizard 2 02-23-2009 01:25 AM
animating built-in vizard male and female avatars vAlexia Vizard 2 09-19-2006 01:06 PM
number of faces to load using the 'old' txt version of avatars bailenson Vizard 1 06-06-2004 12:30 PM
