Old 07-08-2016, 04:33 AM
rajnishv rajnishv is offline
Smile Regarding Projection on Front Wall and Floor
Hi Jeff,
I am developing a demo with Vizard 5,for a client who needs only front wall and floor wall(half way).
I ahve extended the display on front and ground,but unable to get the real immersive ness what i want for thsi kind of projection(front and floor).
I need to configure the demo in such a way that its gives me actual perpective on projection to front wall and floor wall(Half way).
Is there any display mode ,which i can select from Vizconnect GUI,to get such a projection perpective,which give real feel on the floor mainly with relative to front.
I am attaching some images for reference.Pls see to it jeff.
Pls suggest me a solution
-On how to get such type of projection using vizard 5 thru
vizconnect module(if any) or any other?.
Waiting for ur reply jeff.
Mr.Rajnish Vishwakarma
Software Developer
at
Xenium Digital Private Limited,Mumbai(Customer of World Viz)
ID:	796   Click image for larger version
ID:	797   Click image for larger version
Old 07-11-2016, 02:18 AM
If you have an Enterprise license(s) you could use the 'Cave Manual Configuration' option in vizconnect and select front wall and floor. In the 'side image width' field enter the floor depth value.
If you're using a Development license this can be done through vizcave code directly. See the vizcave single machine example. However, there is no built-in vizconnect option available, it would require manual changes to the vizconnect code.
Old 07-12-2016, 12:19 AM
Thanks for ur reply jeff...we have life time enterprise licence of Vizard.
Will test it and will reply back.
How to set offset for ART SmartTrack JB_HP_Viz Vizard 1 06-05-2016 10:02 PM
Four Wall Cave using two client cluster JB_HP_Viz Vizard 3 05-13-2016 03:26 AM
drives two walls with a single PC and an nVidia graphics card su.298@osu.edu Vizard 1 03-30-2012 08:53 AM
Flipped floor in a CAVE shivanangel Vizard 1 03-10-2010 10:12 AM
