Old 05-23-2016, 03:50 PM
JB_HP_Viz JB_HP_Viz is offline
Issue getting ART SMARTTRACK and Flystick3 to work
I’m trying to get the ART SMARTRACK and Flystick3 connected using Vizconnect.
In Vizconnect I have selected DTrack under Add a New Tracker
Information that needs to be filled out:
Name; VRPN NAME; IP address; index;
I have DTrack running and I also have started the VRPN Server, both are running on the local machine that Vizard is running on.
In VRPN config file I have uncommented the line:
vrpn_Tracker_DTrack DTrack 5000
So I assume the values for
Name = dtrack
vrpn name = DTrack
ip = 127.0.0.1
index = 0
Do those values seem correct? Any ideas what else I can try?
When I select Flystick under Add a New Input device the only value is hostname.
I have hostname = localhost.
Does this seem correct? Any ideas what else I can try?
Or if that doesn’t work should I try the Example code at the bottom of this page
http://docs.worldviz.com/vizard/#VRP...vices%7C_____9
If this is better, what would the code look like?
Thank you
John
Here is some additional information:
Information from DTrack configuration file:
[Controller settings]
General:
Hostname : SMARTTRACK-00023
Domain : art.site
DHCP client: no
IP address : 192.168.0.1
Subnet mask: 255.255.255.0
Gateway : none
Nameserver : none
More information on ART SMARTTRACK
http://www.ar-tracking.com/products/...ms/smarttrack/
More information on ART Flystick3
http://www.ar-tracking.com/products/...ion/flystick3/
Old 05-24-2016, 04:11 AM
Take a look at the information in this ART SmartTrack post and try a simple Vizard script to test the connection:
# VRPN Tracker connection (to ART Dtrack)
vrpn = viz.add('vrpn7.dle')
headTracker = vrpn.addTracker('DTrack@localhost')         #Default sensor is 0
flystickTracker = vrpn.addTracker('DTrack@localhost',1)   #Try index 1 or 2 here
flystickButtons = vrpn.addButton('DTrack@localhost')      #Flystick buttons
flystickJoystick = vrpn.addAnalog('DTrack@localhost')     #Flystick analog thumb joystick
Old 06-02-2016, 10:14 AM
Jeff,
thank you. I got both the SmartTrack and Flystick working now.
John
