Old 04-16-2016, 12:42 PM
jelly jelly is offline
problem with path animation
Hello!
I want to run a function 4 times. The function entails that the viewpoint is being animated as to look as it is moving through a maze. The problem is that, while it always loads the function 4 times, the animation only works the first time, after which is stops at the position of the end of the animation. It's as if the viewpoint does not get updated back to its initial setting.
I would be extremely grateful for any help or pointers, because I tried everything I could think of and it is just trial-and-error!
import viz															#Needed to generate a world.
import viztask														#Needed to control the experiment structure.
viz.mouse.setVisible(viz.OFF) 										#Stops the mouse appearing on the screen.
viz.mouse.setOverride(viz.ON)										#Stops Vizard navigation using the mouse.
viz.clearcolor(viz.BLACK)
#Set the start position:
startPos = [-6.4,0,-8]
### Add all the resources. ###############
maze1 = viz.add('Objects/Maze_1.dae')
#maze1.visible(viz.ON)
subwindow = viz.addWindow()
view = viz.addView()
view.eyeheight(1.4)
view.setPosition(startPos)
view.collision(viz.ON)
viz.collisionbuffer(.8)
subwindow.setView( view )
subwindow.setSize( 0.4,0.4 )
subwindow.setPosition(0.3,0.7) #(0,1)
subwindow.visible( viz.ON )
##Animation path
pathMaze1 = viz.addAnimationPath()
#Add control points to the path, along with their time stamp.
pathMaze1.addControlPoint(0,pos=(-6.4,0,-8),euler=(0,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(2,pos=(-6.4,0,-8),euler=(90,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(4,pos=(0,0,-8),euler=(0,0,0),scale=(2,2,2))
pathMaze1.addControlPoint(8,pos=(0,0,5),euler=(0,0,0),scale=(2,2,2))
#Duation of animation
pathMaze1Duration = pathMaze1.getDuration()
#Loop the path in a swinging fashion (point A to point B to point A, etc.).
pathMaze1.setLoopMode(viz.OFF)
def maze1():
	print 'now'
	view.setPosition(-6.4,0,-8)
	link = viz.link(pathMaze1,view)
	yield viztask.waitTime(2)
	pathMaze1.play()
	yield viztask.waitTime(pathMaze1Duration)
def masterFunction():
	for x in range(4):
		yield maze1()
viztask.schedule(masterFunction())
How to create Animation Path Abood Karkar Vizard 2 01-27-2016 06:03 PM
Road Animation Path vserchi Vizard 4 11-12-2015 10:29 AM
Clarification on CAL3D Avatar Animation in Vizard shivanangel Vizard 2 11-22-2010 08:16 AM
Problems with interaction of vizact.turn and animation path Enlil Vizard 3 11-24-2008 05:23 PM
speed on animation path whj Vizard 8 11-17-2008 08:41 PM
