Old 01-05-2016, 02:57 PM
Is that possible to add some actions to the "grabbed object"
the object is grabbed on the mouse or other equipment and I want to add some action to the grabbed object such as spinTo, sizeTo, but different signal input trigger different actions
it is not the "grabber.GRAB_EVENT", this event can only trigger one movement after it is grabbed.
I want to trigger different movement.
Old 01-05-2016, 11:53 PM
You could set a flag when the object is grabbed. When the input signal is sent, check to see if the object is grabbed before applying the action:
import vizconnect
import vizshape
vizconnect.go('vizconnect_config.py')
torus = vizshape.addTorus(radius=0.1,tubeRadius=0.015,axis=vizshape.AXIS_X, pos=[0,1.7,1])
torus.texture(viz.addTexture('images/tile_wood.jpg'))
torus.addAction(vizact.spin(0,1,0,15))
torus.grabbed = False
grabber = vizconnect.getRawTool('grabber')
grabber.setItems([torus])
def onGrab(e):
	if e.grabbed == torus:
		torus.grabbed = True
def onRelease(e):
	if e.released == torus:
from tools import grabber
viz.callback(grabber.GRAB_EVENT, onGrab)
viz.callback(grabber.RELEASE_EVENT, onRelease)
scaleAction = vizact.sequence([vizact.sizeTo(size=[1.3,1.3,1.3],time=1),vizact.sizeTo(size=[1,1,1],time=1)], viz.FOREVER)
def applyScale():
	if torus.grabbed:
		torus.runAction(scaleAction,pool=1)
def removeScale():
	if torus.grabbed:
		torus.clearActions(pool=1)
vizact.onkeydown('1',applyScale)
vizact.onkeydown('2',removeScale)
Old 01-06-2016, 11:04 AM
import vizconnect
import vizshape
def onGrab(e):
def onRelease(e):
def applyScale():
	if torus.grabbed:
def removeScale():
	if torus.grabbed:
is that possible to do these in VizChild object like osgb file
Old 01-06-2016, 12:07 PM
import vizconnect
import vizshape
def onGrab(e):
def onRelease(e):
def applyScale():
	if torus.grabbed:
def removeScale():
	if torus.grabbed:
and also why it shows "VizPrimitive" object has no attribute "grabbed"
Old 01-07-2016, 05:00 AM
Yes, you can also define an attribute such as
for a node3D object created from an osgb file.
I'm not getting the same error. What version of Vizard are you running?
Old 01-07-2016, 08:01 AM
I fixed the problem
I forgot to add the code "viz.callback(grab.GRAB_EVENT,onGrab)"
Simultaneous Actions on Multiple Objects javadi Vizard 2 07-19-2013 03:54 PM
adding actions in front of actionlist IGoudt Vizard 1 01-25-2010 10:55 AM
Trouble with adding actions vijaykiran Vizard 0 10-05-2009 03:18 PM
Speech during actions zoltantoth Vizard 2 05-02-2007 03:11 PM
Weird lagging/choppiness when avatars perform actions vjonshih Vizard 8 11-30-2004 04:08 PM
