Old 11-03-2015, 12:44 AM
Samuli Samuli is offline
How to use grabber tool with wand?
Hi Jeff,
I'd appreciate if you have some knowledge on how to use grabber tool with wand using ppt-tracking and wand 2014? Few more questions: What are proxy tools? What is the proxywrapper/grabberwrapper, their functions and what does the following code snippet from box stacker demo code do?
def init():
	"""Initialize the demo, only called once"""
	# add grabber tools based on proxy tools
	for proxyWrapper in vizconnect.getToolsWithMode('Proxy'):
		grabberTool = tools.grabber.HandGrabber(usingPhysics=True,
												usingSprings=True,
												placementMode=tools.placer.MODE_MID_AIR)
		name = 'box_stacker_grabber_tool_based_on_'+proxyWrapper.getName()
		grabberWrapper = vizconnect.addTool(raw=grabberTool,
											name=name,
											make='Virtual',
											model='Grabber')
		# parent the grabber wrapper to the proxy's parent
		grabberWrapper.setParent(proxyWrapper.getParent())
I can't find any relevant information about these things in the Vizard documentation/reference.
Old 11-03-2015, 03:54 PM
You can add a grabber tool and map the wand input signals to the grabber functions in vizconnect. The vizconnect avatars and tools tutorial covers this topic using a desktop setup but the same concepts apply if you're using PPT tracking and wand. The proxy tool is used with the demo launcher as a placeholder tool. This is most likely unnecessary for your application but a description of the proxy tool is shown when you select it in the vizconnect > tools dialog.
box stacker, grabber, proxy, wand, wrapper
Using highlighter tool with wand Samuli Vizard 2 09-24-2015 01:50 PM
How to get wand tracker? Samuli Vizard 4 09-18-2015 01:09 PM
Wand triggers event Samuli Vizard 1 09-02-2015 04:32 AM
Intersense wand and Head tracker blessonisaac Vizard 0 01-10-2011 04:39 PM
CAVE, navigation, tracked wand, coordinate systems JimC Vizard 6 10-09-2009 01:43 PM
