Old 03-12-2015, 08:08 AM
armo armo is offline
problems with walking women avatars
Hi there,
I am really having a hard time trying to make some women avatars walk. The avatars come from the vizard Complete characters set.
Specifically, the avatar has these strange s-shaped arms visible in the attached picture "strange walking woman.jpg". Here is the code
import viztask
def world():
	global root
	view = viz.MainView
	#add sun-like directional light
	l = viz.addLight()
	l.position(0, 1, 0, 0) #sets light direction
	l.intensity(0.9)
	l2 = viz.addLight()
	l2.position(1, 0, 1, 0) #sets light direction
	l2.intensity(0.8)
	l3 = viz.addLight()
	l3.position(-1, 0, -1, 0) #sets light direction
	l3.intensity(0.6)
	l4 = viz.addLight()
	l4.position(0, 0, 1, 0) #sets light direction
	l4.intensity(1)
	l5 = viz.addLight()
	l5.position(0, -1, -1, 0) #sets light direction
	l5.intensity(0.8)
	#root encapsulates all world geometry
	root = viz.addGroup()
world()
#viz.mouse(viz.OFF)
av_trial = viz.add('avatars_happiness/sportive03_f_highpoly/sportive03_f_highpoly.cfg', pos=( 0, 0, 3 ), euler=(180,0,0))
viz.MainView.setPosition( 0, 1.6, 0 )
# ACTIONS
# walk action
WALK = vizact.walkTo( pos=[ 0, 0, 0 ], walkSpeed = 0.5, walkAnim=44)
def move(av):
	'''the avatar walks'''
	av.addAction(WALK)
# some callbacks to start animation
def HandleKeyboard(key):
	if key == 'w':
		move(av_trial)
viz.callback(viz.KEYDOWN_EVENT, HandleKeyboard)
I am seeing this strange effect on more than one women avatars
However, if I try to substitute the WALK variable with this:
WALK = vizact.walkTo( pos=[ 0, 0, 0 ], walkSpeed = 0.5, walkAnim=viz.AUTO_COMPUTE, verb = 'walk' )
I get instead an even stranger result visible in the attached picture "walkAnim_vizAUTO_COMPUTE.jpg"
but what really puzzle me is that everything works fine with male avatars
Any suggestions?
best regards,
armo
ID:	683   Click image for larger version
Name:	strange walking_woman.jpg
Old 03-13-2015, 08:59 AM
I'll test this out and get back to you.
Old 03-22-2015, 01:57 PM
Hi Jeff
I was wondering if there were any updates on this issue
thanks in advance,
armo
Old 03-23-2015, 09:04 AM
Has the avatar source file been modified and re-exported or is this the original Cal3D model that came with the Complete Character set? I'll try and reproduce the issue here.
Old 03-23-2015, 09:14 AM
Dear Jeff
I am having this problem with the original models from the Complete Character set. No changes on the source file occured.
Old 03-24-2015, 01:42 AM
Please contact support@worldviz.com and we'll open a support ticket for the issue with the arms.
To find the walk animation using the verb argument there must be an entry in the CFG file that has verb + '_animation'. This should be equal to the animation number. Add the following line to the end of the CFG file:
walk_animation = 44
Then when you run the following line of code animation 44 will be applied with the walkTo action:
WALK = vizact.walkTo( pos=[ 0, 0, 0 ], walkSpeed = 0.5, verb = 'walk' )
Old 04-07-2015, 08:38 AM
Erikvdb Erikvdb is offline
I had the same problem with that specific avatar a few months ago. It seems the Skin modifier in 3Ds Max doesn't have the correct skin weights (both the Max model and the exported avatar have this issue).
I guess it was the first time that I used her, so I hadn't encountered the issue before. I wanted to open a ticket, but it was faster for me to simply reskin the model and I forgot about it afterwards
Sorry I couldn't reply earlier.
animation, avatar, walkto
Problems with import of fbx avatars into vizard makinate Vizard 1 12-10-2014 03:49 PM
Problems with avatars facial expressions exported with Cal3D armo Vizard 4 08-28-2014 11:57 AM
How to make avatars to follow terrain while walking? yyang Vizard 1 08-04-2008 03:54 PM
avatars dig Vizard 4 09-20-2007 04:29 PM
Walking avatars --> collision detection? sjroorda Vizard 3 10-13-2005 05:47 AM
