Old 04-09-2015, 11:44 AM
hzlergn hzlergn is offline
Multi-screen Projection
Hello everybody,
I will be glad to see your help with my vizard problem. I need to project my model on two screens and I already have calibration code for the system; but my problem is uploading my own model on both screens. I can just see on one and control through that. What kind of a code can help me to solve this problem ? And also I am just a beginner for coding.
Old 04-09-2015, 07:07 PM
Are you trying to duplicate the view on both screens or is this a CAVE setup with two walls. Can you post example code you are testing with?
Old 04-09-2015, 07:12 PM
I have a CAVE setup and I am trying to use it, but it is approximately 800 lines I guess I can't copy. When I run it with the demo vizard models it works but I can't use it with my own building model.
Old 04-09-2015, 07:20 PM
Are you using a vizconnect configuration file to load the CAVE display and tracking?
Old 04-09-2015, 08:00 PM
As a summary I have one CAVE and one launcher file that works properly. I tried to copy some configuration codes from the launcher file as follows;
I tried to do the same but it gave an error like there is no config file and the problem is that original code depend on that launcher. Since my coding experience is too limited how can I do this in a simple way ?
import Config
viz.requireVersion(R5_REQUIRED_VIZARD_VERSION)
if Config.MULTISAMPLE != 0:
viz.setMultiSample(Config.MULTISAMPLE)
if os.path.exists( trackerPath ):
fileList = os.listdir( trackerPath )
vizconnectLauncher = None
for file in fileList:
if 'vizconnect_config' in file.lower() and '.pyc' not in file.lower():
if 'desktop' in file.lower():
userTrackers.insert(0, file.split('_')[-1].replace('.py', '' ))
userTrackers.append( file.split('_')[-1].replace('.py', '' ) )
elif 'Launch_vizconnect_Control_Interface.py' == file:
vizconnectLauncher = file
if vizconnectLauncher is not None:
userTrackers.append( vizconnectLauncher )
Old 04-10-2015, 06:48 PM
If a vizconnect config file has been configured for your CAVE then you can import that file in your script and add any Vizard code after that:
import vizconnect
vizconnect.go('vizconnect_config_CAVE')
viz.addChild('gallery.osgb')
Displaying screen text in 3D (Oculus Rift) pjayaram Vizard 2 05-27-2014 09:06 PM
Screen Size and Scaling javadi Vizard 2 04-02-2013 06:56 PM
Attach a TexQuad to pit.osgb screen Ducky Vizard 1 01-17-2013 03:57 PM
Projection Matrix (onto oblique near plane) andrewjworz Vizard 1 07-13-2012 10:10 AM
position of html-file on screen active_world Vizard 1 05-16-2008 08:24 PM
