Old 11-14-2014, 07:52 PM
mellott124 mellott124 is offline
InertiaCube settings through vizconnect
When I create a tracker myself within Vizard I have access to things such as:
#Add the intersense tracker
isense = viz.add('intersense.dle')
tracker = isense.addTracker(port=3)
tracker.setCompass(0) #0->OFF, 2-->ON
tracker.setCompassCompensation(1)
tracker.setAccelSensitivity(1)
tracker.setEnhancement(2)
tracker.setPrediction(5)
tracker.setSensitivity(3)
tracker.setShockSuppression(1)
tracker.resetHeading()
How do I gain access to these same things through vizconnect? I cant seem to find the way to access them. I need access directly to them in my application script, not through the vizconnect panel.
Kevin
Old 11-18-2014, 10:57 AM
You can use the following code to get a handle to the sensor:
vizconnect.getTracker().getRaw()
VRPN quaternion conversion from PPT from Intersense InertiaCube willemsn Precision Position Tracker (PPT) 0 07-20-2011 01:59 PM
Integrating InertiaCube and Vicon data roman_suvorov Vizard 10 05-20-2008 04:30 PM
Inertiacube 2 problem theuberk Vizard 1 04-22-2008 04:03 PM
InertiaCube 2 commands vizmaster Vizard 2 09-26-2006 03:20 PM
Problem with newer Intersense Inertiacube 2 esmith4 Vizard 3 03-18-2005 08:13 AM
