Old 06-28-2014, 07:16 AM
armo armo is offline
Problems with avatars facial expressions exported with Cal3D
Hi all,
I am working with the Vizard Complete Characters library and I would like to import into vizard an avatar with a painful facial expression. I modeled this expression in 3DS max and exported it following the instructions of the CAL3D tutorial but I had the strange results you see in the attached screenshots.
Furthermore vizard sends me this error:
Loading File: casual02_m_highpoly_Expressions/casual02_m_highpoly_painful.cfg
** WARNING: Failed to load animation file: male_high_pain.CAF
Warning: Material::setShininess() of 6400 is above permitted maximum, clampping to 128.
** Load Time: 0.12 seconds
Could you please tell me where is the error?
Here's the source code:
viz.MainView.setPosition( 0, 1.5, 0 )
av_painful = viz.add('casual02_m_highpoly_Expressions/casual02_m_highpoly_painful.cfg', pos=( 0, 0, 1.5 ), euler=(180,0,0))
neutral = vizact.morphTo( 0, 0, 1 )
pain = vizact.morphTo( 0, 1, 1 )
wait = vizact.waittime(vizact.randfloat(1,5))
action = vizact.sequence( wait, neutral, pain, viz.FOREVER )
av_painful.addAction(action)
and here's the .cfg file:
# Cal3d cfg File
scale=0.01
flip_texture = 1
################# Skeleton #################
skeleton=male_high_Skeleton.CSF
################# Meshes #################
mesh=casual02_m_highpoly.CMF
morph=casual02_m_highpoly_pain.CMF
mesh=casual02_m_highpoly01.CMF
################# Animations #################
animation=male_high_pain.CAF
################# Materials #################
material=casual02_m_highpoly.CRF
material=casual02_m_highpoly01.CRF
thank you very much,
armo
ID:	656   Click image for larger version
Old 07-01-2014, 01:28 PM
Make sure the number of vertices in the morph mesh matches the number of vertices in the base mesh. Also the materials need to have "[number]" at the end of their names in Max. This is explained at the beginning of the of the exporting section in part 4:
http://download.gna.org/cal3d/docume.../tutorial.html
I'll put together a small knowledge base article in the next few days with some guidelines for setting up and exporting the morph targets.
Old 08-24-2014, 02:57 PM
Dear Jeff
Excuse me for resuming this post after so long, but I am still having some problems in getting the entire exporting process correct, particularly in the material files loading.
I have attached the result of my modified avatar when I load it in vizard. The texture of the face still doesn't show (everything else works fine: equal number of vertices, bones, animations and morphs).
Here's the sequence of steps that I make when I export materials:
1-I open the material editor in 3ds MAX and rename the body texture as "body[0]" and the hair_transparent as "hair_transparent[1]"
2-I open the export command, choose .CRF format, name it "casual02_m_highpoly.CRF" and choose "body[0]" in step 1, and then "casual02_m_25.tga" in step 2
3- I make the same sequence for "casual02_m_highpoly01.CRF" and "hair_trasparent[1]", but this time I never find any .tga file in step 2
below is the .cfg file
# Cal3d cfg File
scale=0.01
flip_texture = 1
skeleton=male_high_happy_Skeleton.CSF
morph=casual02_m_highpoly_blink.CMF
morph=casual02_m_highpoly_ebrow.CMF
morph=casual02_m_highpoly_talk.CMF
morph=casual02_m_highpoly_happy.CMF
animation=male_high_basepose.CAF
animation=male_high_beatenup.CAF
animation=male_high_breakdown1.CAF
animation=male_high_breakdown2.CAF
animation=male_high_cheer.CAF
animation=male_high_claphands.CAF
animation=male_high_dance.CAF
animation=male_high_drivecar.CAF
animation=male_high_drivemotorbike.CAF
animation=male_high_drown.CAF
animation=male_high_duck.CAF
animation=male_high_eatsitting.CAF
animation=male_high_fight.CAF
animation=male_high_holdpistol.CAF
animation=male_high_idle1.CAF
animation=male_high_idle2.CAF
animation=male_high_idledrunk.CAF
animation=male_high_idlewall.CAF
animation=male_high_jumpforward.CAF
animation=male_high_lierelaxed1.CAF
animation=male_high_lierelaxed2.CAF
animation=male_high_listen.CAF
animation=male_high_lookaround.CAF
animation=male_high_manipulate.CAF
animation=male_high_pickup.CAF
animation=male_high_putitem.CAF
animation=male_high_run.CAF
animation=male_high_runcarry.CAF
animation=male_high_shoot.CAF
animation=male_high_shout.CAF
animation=male_high_sitground.CAF
animation=male_high_sitidle.CAF
animation=male_high_skate.CAF
animation=male_high_stairs_down.CAF
animation=male_high_stairs_up.CAF
animation=male_high_strafeleft.CAF
animation=male_high_straferight.CAF
animation=male_high_swim.CAF
animation=male_high_talk1.CAF
animation=male_high_talk2.CAF
animation=male_high_throw.CAF
animation=male_high_tigerjump.CAF
animation=male_high_useitem.CAF
animation=male_high_walk.CAF
animation=male_high_walk_inplace.CAF
animation=male_high_walkcarry1.CAF
animation=male_high_walkcarry2.CAF
animation=male_high_walkdrunk.CAF
animation=male_high_walkinjured.CAF
animation=male_high_walkpush.CAF
animation=male_high_workassembly.CAF
animation=male_high_workcomputer.CAF
best regards,
armo
Old 08-26-2014, 03:43 PM
Kevin Chiu Kevin Chiu is offline
Hi Armo,
You will still need to choose "body[0]" when exporting both the "casual02_m_highpoly.CRF" and "casual02_m_highpoly01.CRF" hence the "hair_trasparent[1]" is not an existing tga texture.
Best,
Kevin
Old 08-28-2014, 11:57 AM
Hi Kevin,
Thank you very much! now it works properly.
best regards,
armo
animation, avatar, cal3d, export, morphto
Error using CMF export from 3ds max to cal3d in some avatars disbeat Vizard 4 04-16-2014 12:40 AM
Cal3D avatars Adam.Grey Vizard 2 01-18-2012 02:52 PM
Problems exporting with Cal3D Deltcho Vizard 1 08-03-2010 04:27 PM
importing avatars with cal3d marcoleon Vizard 15 04-28-2006 05:48 PM
Using Cal3d Avatars zachhendershot Vizard 4 01-27-2004 11:26 AM
