Old 08-14-2014, 01:05 PM
roobert roobert is offline
Send a message via Skype™ to roobert
Lightbulb Walk
I'm using the kinect and want to know if you can walk through a scene for example (piazza.osgb) with my motion detection.
There is some information about this...
Old 08-15-2014, 03:10 PM
Yes, you can link the viewpoint to the kinect head sensor. If you're going to be using this for head tracking we recommend using a separate orientation sensor (e.g. inertial sensor) for smoother orientation updates.
Old 08-15-2014, 04:26 PM
Jeff.
no doubt, you are a genius.
Thank you.
Old 08-15-2014, 05:55 PM
If I use a model eg(piazza.osgb) the model position is in middle of my body, How I put the floor model put on my feet?
Old 08-18-2014, 03:41 PM
It sounds like the head sensor height you're getting is too low. Can you post the code you're using?
Old 08-18-2014, 05:39 PM
I am use Kinect.
I can not see the hands, does the kinect not detect distances?
import vizshape
lugar=viz.add('piazza.osgb')
vrpn = viz.addExtension('vrpn7.dle')
Cabeza = vrpn.addTracker( 'Tracker0@localhost',0)
l = viz.link(Cabeza,lugar)
HeadRigth=vrpn.addTracker( 'Tracker0@localhost',14 )
ManoDerecha=viz.add('hand_gloved_R.osgb',scale=[.5,.5,.5])
md=viz.link(HeadRigth,ManoDerecha)
HeadLeft=vrpn.addTracker( 'Tracker0@localhost',8 )
ManoIzquierda=viz.add('hand_gloved_L.osgb',scale=[.5,.5,.5])
mi=viz.link(HeadLeft,ManoIzquierda)
Old 08-19-2014, 08:07 PM
If you test with the script at the bottom of the following article and move the viewpoint do you see all the tracker points in Vizard?
http://kb.worldviz.com/articles/1584
kinect, walk, walkto
random walk in piazza environment maya Vizard 7 01-15-2014 05:58 AM
custom avatar random walk krimble Vizard 2 03-20-2007 04:23 AM
executing a turn in the middle of a walkto action v-clizzin Vizard 1 09-18-2006 03:31 PM
Avatar walk betancourtb82 Vizard 5 03-21-2006 10:14 AM
Object.remove() Johannes Vizard 30 03-08-2006 11:13 AM
