Old 02-23-2006, 01:24 PM
kgarr kgarr is offline
frame rate lock?
Simple question: Is the framerate limited to 60fps in v2.53 or is that just the demo? If so, is it adjustable?
Old 02-23-2006, 01:34 PM
No, this is a feature of your graphics card. Most graphics cards will limit the frame rate of the application to the refresh rate of your monitor. They do this because there is no point to render extra frames if your monitor won't be able to display it in time. You can either go into the settings for your graphics card and disable "Vertical Sync". Or you can issue the following command in your script:
viz.vsync(0)
Now your script will render frames as fast as possible.
