Old 02-13-2006, 08:04 AM
cantwelljm cantwelljm is offline
Question lighting issue
Hi I am new to vizard, I have created a model of a building in Autodesk 3DS Max 8. I have set up a daylight scene in 3DS. I am exporting the building to vizard in .3DS format, but when I import the model in vizard there are no lighting affects. How can I carry my lighting affects through to vizard?? Any help would be greatly appreciated.
Old 02-13-2006, 03:08 PM
tobin tobin is offline
The most robust method of exporting lighting effects is through the OSG exporter for Vizard. You can download this exporter for MAX 8 (anb 5, 6, and 7) here:
www.worldviz.com/products/vizard/tools.html
(note that this pages was recently changed and now links to new exporter plug-ins)
If you new to real-time lighting issues, you should know the following: 1) Vizard supports omni, spotlight, and directional real-time lights. Other real-time lighting effects within Max are not supported. However, for static lighting of a scene, you can obtain very sophisticated results using Max's render-to-texture features. The OSG exporter supports these baked texture results.
When you export your scene, you can suffix your files either with .OSG or .IVE. The formats are functionally equivalent but the latter embeds the image data within a binary file and therefore while much larger in size it loads incredibly fast and is free of supporting texture files/directories.
Old 02-18-2006, 08:43 AM
Question (Beginner) lighting issue
When you said Vizard only supports omni, spotlight, and directional real-time lights, if I am using the render to texture function can I then use any form of lighting eg. photometric lights or Daylight??
Old 02-18-2006, 09:21 AM
Yes, with render to texture you can use all of Max's ligthting, shadowing, reflections, etc. It's not real-time in the sense that you can't make adjustmenets to these (e.g., move the lights) in real-time. But once rendered to texture, the scene can be certainly visualized within Vizard in real-time.
