Old 06-22-2014, 12:44 AM
agrima agrima is offline
Question animate an object using 5dt data glove 5 ultra
hi;
I have to animate i.e, control the motion of an object using data glove.
I tried grabbing the object , but now i dont know how should i try moving the object in accordance to my glove. I am posting the code below:
import vizcam
import random
import hand
viz.setMultiSample(4)
viz.fov(60)
#viz.go(viz.QUAD_BUFFER)
#viz.go(viz.HALF_RESOLUTION)
PORT_5DT_USB = 0
sensor = viz.addSensor('5dt.dls')
glove = hand.add(sensor,hand.GLOVE_5DT)
vase = viz.add('vase.ive')
vase.setPosition(-160,40,-30)
models={'9.ive'}
model1=viz.add('9.ive')
viz.MainView.setPosition(-160,50,130)
viz.MainView.setEuler(180,00,0)
gestureName = ['Fist', 'Index finger point', 'Middle finger point',
'Two finger point', 'Ring finger point', 'Ring-Index finger point',
'Ring-middle finger point', 'Three finger point', 'Little finger point',
'Index and little finger point', 'Little-middle finger point',
'Not ring finger point', 'Little-ring finger point',
'Not middle finger point', 'Not index finger point',
'Flat hand', 'Undefined']
def getGesture():
gesture = int(sensor.get()[-1])
if gesture == 7:
#three finger
viz.MainView.setPosition([0,0,0.05],viz.REL_PARENT)
if gesture == 8:
#Little finger point
viz.MainView.setPosition([-0.05,0.0,0],viz.REL_PARENT)
if gesture == 9:
#Little finger and index point
viz.MainView.setPosition([0.05,0.0,0],viz.REL_PARENT)
if gesture == 3:
#two finger point
viz.MainView.setPosition([0,0.0,-0.05],viz.REL_PARENT)
if gesture == 1:
#Index finger point
viz.MainView.setPosition([0,.05,0], viz.REL_PARENT)
if gesture == 0:
#Fist
#vase.setPosition([0,-.05,0], viz.REL_PARENT)
viz.MainView.setPosition([0,-.05,0], viz.REL_PARENT)
if gesture == 14:
viz.link(glove,vase)
viz.grab(glove,vase)
vizact.ontimer(0, getGesture)
Old 06-23-2014, 05:43 AM
The 5dt glove does not provide position data of the hand. Some models provide pitch and roll. Most of the measurements are related to finger movements and hand gestures. You'll need an additional position/orientation tracker mounted on the glove for hand tracking. You can link the glove to the data from a physical tracking device (e.g. PPT, inertia cube) or a virtual tracker using keyboard/mouse inputs. The following code links the glove to a keyboard tracker:
#Create virtual tracker using WASD and other key inputs
import viztracker
handTracker = viztracker.Keyboard6DOF()
#Link the hand to the handTracker
gloveLink = viz.link(handTracker, glove)
Then you can link the vase directly to the handTracker:
vaseLink = viz.link(handTracker, vase)
or to the gloveLink:
vaseLink = viz.link(gloveLink, vase)
For future posts, please use code tags to preserve indentation. You can find the guidelines for posting code here.
Old 06-23-2014, 10:35 PM
i incorporated the above 3 lines mentioned by you, but now the main view is not at the correct location, it shows the view at the corner of the screen.I tried changing the co-ordinates but in vain.
This problem occurred after i wrote viztracker.go() without which the vase was not responding to keyboard commands.
Old 07-01-2014, 12:17 PM
Are you using viztracker with a vizsetupcfg.py configuration file? If so, then the setup file should contain the code to connect to the glove. In the application that imports the config file, you can get a handle to the hand and link the vase to it. Can you attach your vizsetupcfg.py file if you have one?
data glove navigation arielasso Vizard 6 10-24-2007 03:15 PM
Use of 5DT Ultra left handed glove pattie Vizard 1 08-26-2006 01:59 PM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 05:08 PM
5DT Data Glove 5 Ultra Flexure Question bjgold Vizard 1 07-25-2006 03:58 PM
