Old 04-24-2014, 09:00 AM
chris2307 chris2307 is offline
Displaying Text on new Window
Hi all,
I have an application which can either run in single screen mode or three screen mode.
Single screen mode uses viz.MainView only and three screen mode, I use three custom windows.
My only problem is when I attempt to display text in the centre of the application. The parent of the text by default is viz.SCREEN. I attempt to reset this if I am in three screen mode to the centre screen.
Unfortunately, I don't see the text. I don't get errors either.
Screen Code:
# The following is also done for the left window and right window.
centreWindow = viz.add(viz.WINDOW)
centreWindow.setPosition(1.0/3, 1.0)
centreWindow.setSize(1.0/3, 1.0)
centreWindow.visible(0,viz.SCREEN)
centreWindow.fov(fieldOfView,aspectRatio)
centreView = viz.add(viz.VIEWPOINT)
centreWindow.setView(centreView)
def returnScreen():
	if(threeScreen):
		return centreWindow
		return False
Here is my default text code:
self.trialInstructions = "TEXT"
self.text = viz.addText(self.trialInstructions, parent=viz.SCREEN)
self.text.color(viz.WHITE)
self.text.setPosition(0.5,0.5)
self.text.alignment(viz.ALIGN_CENTER_CENTER)
self.text.fontSize(40)
self.text.visible(viz.OFF)
During three screen mode, I run this code:
if not(screen.returnScreen() == False):
	print otherScreen
	self.text.setParent(otherScreen)
self.text.visible(viz.ON)
Can anyone see the mistake I am making?
Old 04-25-2014, 09:03 AM
If you only want the object to show up on a specific window, then use the renderOnlyToWindows command. Example:
self.text.renderOnlyToWindows([centreWindow])
input from a text file dig Vizard 5 10-20-2013 01:20 AM
Window always on top madeinjava Vizard 4 08-27-2013 02:10 PM
Unexpected Change of Window Size javadi Vizard 7 07-23-2013 02:56 PM
winviz in Vizard 4and displaying a console window Enlil Vizard 2 02-22-2012 02:35 PM
Informationboxes with text snoopy78 Vizard 3 07-16-2009 10:23 AM
