Old 08-28-2013, 04:02 AM
bzyqo bzyqo is offline
Wink how i can set MainView orientation?
Hello there
I have small issue here, i cant set up a main view orientation. code bellow does not work.
viz.MainView.setEuler(0,0,0)
Old 08-28-2013, 09:25 PM
Kevin Chiu Kevin Chiu is offline
The code should works, you feel it didn't work because you didn't give any amount of degrees in Euler to the viz.MainView.setEuler() function.
So it remains looking forward, try to put some number in it and it should change your main view orientation.
Here is also some information for your reference.
http://docs.worldviz.com/vizard/Movi..._viewpoint.htm
Problems with linking Sensor to MainView escmo Vizard 2 06-25-2013 01:15 AM
Mainview can't go back to original point jacky Vizard 1 06-04-2013 04:22 AM
How to keep the Orientation of mainview same as the world coordinates in the vizard jacky Vizard 1 05-17-2013 12:01 PM
MainView and getEuler shivanangel Vizard 1 01-20-2012 10:31 AM
problem in setting the orientation of bones bharatbhushan Vizard 0 06-30-2009 04:30 AM
