Old 07-31-2013, 05:37 AM
CompSci CompSci is offline
WxPython & Vizard Issue
Are there any specific instructions or codes needed to run wxPython code with Vizard code? WxPython works fine when I run the code on it's own but when I run the codes together it does not work.
Old 07-31-2013, 05:49 AM
Are there any specific instructions or codes needed to run wxPython code with Vizard code? ** The codes work fine when I run them on their own but when I run the codes together it does not work.
Old 07-31-2013, 09:01 AM
Can you be specific about what exactly does not work? Are you getting any error messages? Have you tried the wxPython sample in our knowledge base:
http://kb.worldviz.com/articles/72
Old 08-05-2013, 07:47 AM
Thanks for the link. The code from the knowledge base is viz.embedded. It embeds' Vizard into wxPython and runs using wxPython. I am looking for a code that will allow me to add a wxPython created GUI element (scroll bar) to a Vizard panel. I want to be able to run using Vizard. Do you know how I would do that?
Thanks again!
Old 08-05-2013, 02:31 PM
Items added to a vizdlg panel must be Vizard node3D objects. The wxPython libary has its own objects for grouping controls.
Old 08-06-2013, 04:38 AM
Ok, thank you.
wxPython with Vizard farshizzo Vizard 18 09-29-2005 08:49 AM
vizard 2.5 compatability issue shai Vizard 3 08-10-2005 04:35 PM
