Old 07-23-2013, 10:14 AM
CompSci CompSci is offline
Uploading & Reading In Data
Is there a way to upload/read-in a file from an environment. I wanted to write a code that will play a video that a user creates.
While in the environment the user would press a button that would prompt him/her to enter a file name or direct them to choose a video file. The selected file would then be played in the environment.
Old 07-23-2013, 01:41 PM
You could read in the video file names from a file and load those into a dropdown list that the user selects from. Or you could have the user select the file from a vizinput.fileOpen dialog. The open dialog is documented on the vizinput dialogs page.
Old 07-24-2013, 05:31 AM
Thanks, I will give this a try.
Use saved text file data as replay sources problem mizutani_jun Vizard 4 10-14-2010 05:49 PM
Reading sensor data via UDP Jeethridge Plug-in development 1 08-24-2010 11:51 AM
Flagging the Data Elittdogg Vizard 5 04-11-2008 12:40 PM
tracking using quaternarion data jfreeman Vizard 2 06-01-2005 09:48 AM
A simple Plug_in for reading data from serial port sled Plug-in development 0 08-12-2003 10:52 AM
