Old 07-22-2013, 12:10 PM
brunomartelli brunomartelli is offline
3dcompass
Hi im trying to make a 3d compass like a flat disc that sits on the ground and rotates in place.
so far i am doing this:
compass = viz.addChild('arrow.osgb')
compass.color( 0.2,0.8,0.8 )
# get the main viewpoint and link a compass to it
view = viz.MainView
#link compass pos to viewpoint
compasslink = viz.link(view, compass)
pitch, roll, yaw = view.getEuler()
compasslink.setEuler([0,0,-yaw])
#offset compass origion before linking to view
compasslink.preTrans([0, -0.5, 0])
this rotates fine, opposite to the view rotate. However if I pitch up the view LMB+RMB the compass doesn't rotate up with the view.
so i figure that i can set the -pitch to rotate it opposite.
compasslink.setEuler([-pitch,0,-yaw])
However That does nothing. I know there is HEAD_ori etc but that does nothing too. Any ideas???? im really stuck....
Old 07-23-2013, 03:22 PM
If you want the compass to rotate with the viewpoint you can create a link and set the mask to orientation only. If you want the compass yaw to be the opposite of the viewpoint use the link.swapEuler command:
import vizshape
viz.add('dojo.osgb')
compass = vizshape.addArrow()
compass.setPosition([0,0.5,0])
compassLink = viz.link(viz.MainView,compass,mask=viz.LINK_ORI)
#Negate yaw value
#compassLink.swapEuler([-1,2,3])
subWindow = viz.addWindow(pos=[0.5,1])
subWindow.setSize(0.5,0.5)
view = viz.addView()
view.move([0,-1,-4])
subWindow.setView(view)
compass, euler, view rotate
