Old 05-08-2013, 01:17 PM
nkinerd nkinerd is offline
Weird colors exporting OSGB from 3DS
New here. Trying to export some textures to Vizard with the OSGB plugin. However, when using the plugin to export, my textures become all psychedelic. I've attached some SS of what the textures look like and my export options in 3ds with the OSGB plugin. If anyone has any suggestions, I'd gladly accept them
I've tried several ways adjusting lots of options in the exporter to no avail. Also swapped out several textures. Anything with a bitmap in the diffuse channel seems to be affected.
From Left to right the attachments are:
Weird texture as it exports, exporting options part 1, part 2, and lastly the original texture image.
ID:	593   Click image for larger version
ID:	594   Click image for larger version
ID:	595   Click image for larger version
Old 05-09-2013, 01:30 PM
So maybe it is a problem with vizard 4.0 compatibility with either OSGB format and 3ds 2014, or just general compatibility with 3ds 2014
I tried exporting the files as OSG instead of OSGB and so far the non binary format, OSG seems to work ok. Not sure if I should put this into a ticket or just use OSG until 3ds 2014 and vizard 4.0 become more compatible with each other.
Old 05-09-2013, 03:53 PM
I am not able to reproduce the issue using the sample image you provided. Would you mind creating a zip file containing the max file and related images and uploading it to our support team ( http://upload.worldviz.com/ )?
Weird texture on .ive model viewed from Sensics HMD Zhi Vizard 11 02-25-2013 04:38 AM
Problem exporting to Cal3d from Max 8 dropshadow79 Vizard 3 01-13-2010 11:16 AM
Trouble Exporting to .ive le perdusier Vizard 2 11-27-2007 04:31 PM
Exporting from Maya to Vizard jfreeman Vizard 2 06-30-2005 02:14 PM
