Old 01-17-2013, 02:01 PM
Green Green is offline
newly installed vizard does not work
I recently installed Vizard 3 in my new desktop Mac. When I tried to run some programs, mistakes appeared, "Producer::VisualChooser: unable to setup a valid visual with WGL extensions, switching to compatibility mode", "Already have a texture in the diffuse channel".
This is very weird, since it is a newly brought Mac, so the display card should not be a problem. And my labmate has the same type of computer. He has installed it and everything is working fine now. I installed windows 8 in the Mac desktop. Is that the problem? Our lab did the same thing before, but vizard 3 worked fine.
Then I installed Vizard 4 in my computer, and now the mistakes are changed, "Warning: BlendColor::apply(..) failed, BlendColor is not support by OpenGL driver.", "Warning: BlendColor::apply(..) failed, BlendColor is not support by OpenGL driver. "PNG lib warning : Interlace handling should be turned on when using png_read_image"
Anyone has a clue what's wrong with my installation?
Thank you so much!
Old 01-24-2013, 06:40 PM
Vizard only runs on a Windows OS. If you're running on Windows and getting OpenGL error messages it sounds like a problem with the OpenGL support of your video card.
Old 01-29-2013, 11:38 AM
Is there a way to fix it? My lab mate also installed vizard in the windows system in a Mac desktop, and it works fine.
Thank!
-Green
Old 01-31-2013, 12:15 PM
You can try updating the drivers of the graphics card.
Does Vizard work on 3D Laptop johnnyiowa Vizard 1 01-05-2011 12:30 AM
newbie problem getting vizard to work Colin Vizard 2 11-10-2006 10:54 AM
