Old 11-29-2012, 03:27 AM
fordprefect fordprefect is offline
Exception in module vizjoy
Dear all,
while modifying our scripts I ran into an exception from the vizjoy module. While it is not much of a problem because the exception is thrown when closing the simulation, I'd like to get rid of it because it could obscure a true error. The programming goes like this:
script.py
import A
A.go()
module A.py
import B
import vizjoy
status = True
def go():
  B.start()
  status = ...
module B.py
import A
def start():
  """does some inits and install callbacks"""
def react():
  if A.status:
I found no way around this circular import of modules because I need access to the current value of A.status in Module B. I tried a getter-Method in A but this also throw me this exception:
Exception TypeError: "'NoneType' object is not callable" in <bound method _JoystickCleanup_.__del__ of <vizjoy._JoystickCleanup_ instance at 0x04787418>> ignored
Appreciate any hints, ideas and even solutions...
BR Walter
21 is only half the truth.
Old 11-30-2012, 12:13 PM
The next release of Vizard should prevent this exception from occurring. Either way, it would be best if you could prevent the circular import. Can you place the status field in the B module?
Old 12-03-2012, 02:41 AM
Hi farshizzo,
thanks for this idea. From a conceptual viewpoint, the status variable belongs to module A, as the status is updated there. Module B only references the status, and was designed to only be an optional module.
Being practical, I agree that this should solve the problem. Thank you.
BR Walter
'module' object is not callable??? tokola Vizard 2 11-21-2012 11:48 AM
physics engine exception ad_astra Vizard 3 03-25-2009 12:31 PM
Free data table GUI module Gladsomebeast Vizard 1 12-23-2008 12:30 PM
Fading/lightening-Problem and viz.go in module Johannes Vizard 6 09-02-2005 05:28 PM
vhil module vadrian Vizard 2 01-27-2005 12:52 PM
