Old 02-17-2011, 12:25 PM
disbeat disbeat is offline
Change license to a new computer
What do I need to do to change my license from the current computer where I've been using it to a new one? I'm planning on buying a new machine and want to know if the process is simple.
Cheers,
Marco Simões
Old 02-18-2011, 11:29 PM
hosier hosier is offline
Vizard provides a way to unregister a license and then provide you a way to get a new license. I've had to do this a few times moving my floating license server around.
From a command prompt on your computer, change to the bin directory under the location you've installed Vizard. From there type:
winviz UNREGISTER
Follow the instructions that come up, and when it's done, it should provide you a code to show you've unregistered Vizard.
Once you've installed Vizard on your new computer and have the new hardware code for it, take that and the unregister code and send this to support@worldviz.com. The should send you a new license code for the new system.
I've had to move my floating server twice so far and haven't had any issues either time.
Aaron
Old 02-19-2011, 05:25 AM
That's exactly what i needed
Marco Simões
Old 10-26-2012, 05:43 AM
unabhan unabhan is offline
HI,
is this procedure stull up tp date for moving Vizard3 licenses?
I'll have to replace a computer soon and will have to unregister the license befre tha harddrive has his last day...
Agnes
Old 10-29-2012, 02:36 PM
Yes, take a look at the page that applies to your license:
Unregistering your stand alone license
or
Unregistering your network license server
under Getting Started->Installing Vizard->Activating your license in the Vizard 3 documentation for more details on navigating in the command window.
Formatting Vizrad's Computer ohad Vizard 1 03-15-2010 12:54 PM
Change model alpha and memory leak hosier Vizard 2 06-25-2009 10:55 AM
Floating license server problems jrodman Vizard 2 10-30-2006 10:39 AM
For users with a floating license: Adding Vizard License Server as a Service mspusch Vizard 0 03-03-2006 11:36 AM
