Old 09-01-2005, 12:51 AM
Gilliard Gilliard is offline
How to synchronize play/pause of 2 video streams in stereo
I prepare an application in which both left and right channels in stereo mode must display different avi (or mpeg) video streams.
The video must be started / stopped, of course both channels exactly on the same frame.
But, due to the fact that 2 python commands are needed to play/pause the 2 "cameras", it sometimes happens that one stops or starts before the other, in which case both streams are no more synchronized.
Is there a mean to play / pause 2 video streams exactly on the same frame ?
Here an excerpt of my code :
	self.leftcam = viz.add(self.leftEyeMovie, viz.TEX_RECT)
	self.rightcam = viz.add(self.rightEyeMovie,viz.TEX_RECT)
	leftquad.texture(self.leftcam)
	rightquad.texture(self.rightcam)
def play(self):
	if self.playBoth: ## 2 commands cannot always act at the same time
		self.leftcam.play()
		self.rightcam.play()
	elif self.playLeft:
		self.leftcam.play()
	elif self.playRight:
def pause(self):
	if self.playBoth:
		self.leftcam.pause()
		self.rightcam.pause()
	elif self.playLeft:
Bertrand Gilliard
Old 09-01-2005, 08:58 AM
Are you noticing a synchronization issue with the sample code you supplied? Media files have a jumpto command which can jump playback to specific time in the video. Other than that, the only way to have the videos be perfectly synchronized is to combine them into a single video that displays them side by side.
