Old 11-04-2011, 11:47 AM
EnvisMJ EnvisMJ is offline
Shape Puzzle Simulation
I'm doing some research into fine object manipulation in virtual space, I'll be using an Intersense wand and glove for input.
I need to replicate the experience of one of these toys:
http://consultantsale.com/images/yvonne/ShapeOToy.jpg
Except the holes will be in a wall in front of the user, rather than in a ball.
Is the Physics engine within Vizard capable of accurately simulating this?
As in, if I have the shape in hand can Vizard accurately prevent the shape from entering the hole if it is the wrong hole, or improperly oriented?
Thanks for your input,
Old 11-07-2011, 01:13 AM
sleiN13 sleiN13 is offline
Isn't it easier to just check the x, y , yaw, pitch, roll values when the object tries to move past a certain z value ?
Old 11-11-2011, 11:03 AM
That is my Plan B, Plan C is switching to Unity (which doesn't actually work in our CAVE at the moment....)
Can this be done in such a way that it isn't jerky and jumpy?
Old 11-11-2011, 11:15 AM
In simplest terms, could I program a plane on the surface of the wall that won't let an object pass through unless oriented properly. Haha, kind of like a force field I guess.
Old 11-16-2011, 06:30 PM
Yes, if the object is not oriented properly when it reaches the plane you can limit it's movement in that direction.
water simulation shahramy Vizard 0 10-15-2011 02:22 AM
Driving simulation with infinite roadway rlh001 Vizard 1 09-12-2011 08:33 AM
Driving simulation miles Vizard 16 06-14-2011 01:53 PM
Looking for a shape imperialkat Vizard 4 07-06-2010 01:02 PM
How to pause the Vizard simulation? 4711 Vizard 4 03-18-2010 05:45 PM
