Old 05-19-2010, 06:59 AM
tsgk tsgk is offline
Joystick setForce
Hello all,
I have a (hopefully) quick question with regards to one of the joystick options, the <vizjoy:joystick>.setForce([x,y]) where [x,y] is the force vector you want to set to the FFB device.
Has anyone used this command succesfully to moderate the strength of the FFB? There are no examples in the Help files.. Help!! How do I use this? What values can I put to the force vector?
Thanks in advance!!
Old 05-31-2011, 05:35 AM
levisii levisii is offline
did you try the <vizjoy:joystick>.hasFFB() function? I was wondering too, why I'm not able to generate any ff-effect. Seems like the ffb-function of my joystick can't be identified. This is my testprogram:
import vizjoy
joystick = vizjoy.add()
print 'FFB = ' + str(joystick.hasFFB())
def joyButton(e):
	if e.button == 1:
		joystick.addForce(0.5,0)
		print '1'
	if e.button == 2:
		joystick.setForce(0,0.5)
		print '2'
	if e.button == 3:
		e.joy.addAction(vizjoy.recoil(0.8))
		print '3'
	if e.button == 4:
		e.joy.addAction(vizjoy.rumble(0.4))
		print '4'
viz.callback(vizjoy.BUTTONDOWN_EVENT,joyButton)
this is my print out:
** NOTIFY: 1 joystick(s) detected
1 - Logitech Force 3D Pro
** NOTIFY: Connected to Logitech Force 3D Pro
Supported: X Axis, Y Axis, Rz, Slider, 12 Buttons, Hat switch,
FFB = False
Old 06-07-2011, 07:09 AM
update:
Well, it was just a problem with the driver. The example is working now.
changing the gain of a joystick during a program Saz Vizard 4 06-25-2009 04:49 AM
How to get the data from Logitech G25 racing wheel ? fuyonggang Vizard 4 12-18-2008 07:14 PM
writing joystick position to a data file Saz Vizard 3 12-17-2008 06:18 AM
Joystick Navigation Vinicius Lima Vizard 7 10-23-2007 11:42 AM
Facetracking and Immersion Joystick Vygreif Vizard 1 01-25-2006 11:56 AM
