Old 05-15-2011, 09:53 PM
Darkmax Darkmax is offline
granny render to texture image
hi i know this is maybe not the best place to post this but i don't know where else to post it.
when i load a model with a texture using render to texture it show me a very low quality texture for example this one:
http://imageshack.us/photo/my-images/220/showe.jpg/
and i tried to render the texture with 1024x1024 and 2048x2048? some suggestions, because i'm in a little hurry i have to finish this project for tomorrow so i hope this could be fix quickly
Old 05-15-2011, 11:01 PM
also i forgot to mention that i'm using vray to render the images
Old 05-16-2011, 04:31 PM
Are you using the S3TC Texture compression? If it’s set to IMAGE_DATE_FORMAT, the size will be bigger, but it wont have any compression. S3TC_ DXT5_COMPRESSION compresses and maintains the texture quality best.
What are the UV coordinates like? Maybe not enough room is allocated to receive textures. If that’s the case, it might also serve to break up the object to receive more texture sheets.
Getting data from a render texture Joran Vizard 3 06-03-2013 03:11 AM
black lines with render to texture Darkmax Vizard 5 03-07-2011 12:23 PM
