Old 09-04-2012, 01:46 PM
mhead10 mhead10 is offline
Sensable Open Haptics-"Failed to load plug-in: 'sensable3.dle'"
I am trying to use Sensable's Open Haptics (version 3.1) with Vizard 3.0. Therefore, I am using
sensable=viz.add('sensable3.dle') in Vizard like docs.worldviz suggests. However, I still get the following error:
Failed to load plug-in: 'sensable.dle'
Therefore, I am wondering if my problem is that Open Haptics Academic Edition does not come with a license (since I know O.H.'s is installed). I called Sensable and they said a license is not required to run, and therefore it was Vizard's fault.
I installed all 3 different versions of Open Haptics with the same result.
Any help will be appreciated.
Thanks!
Old 09-04-2012, 01:51 PM
The documentation you linked to is for Vizard 4.0. Vizard 3.0 only supports OpenHaptics 2.0. You will either need to downgrade to OpenHaptics 2.0, or upgrade to Vizard 4.0.
Old 09-04-2012, 02:40 PM
Thanks for your amazingly quick reply!
I previously read you saying thing earlier, but didn't explicitly read this anywhere.
Anyways, after trying 2.0 O.H.'s again (and fixing some driver errors) it looks like it should work.
Thanks again for your help!
