Old 02-09-2011, 09:38 AM
IsaDuarte IsaDuarte is offline
How to pick objects with joystick?
Hi all,
I am trying to use the joystick to navigate, however i am not able to pick objects with it as I am with the mouse, as here:
def pickChair():
object = viz.pick()
if object==chair1 or object==chair2:
if object.valid():
object.visible(viz.OFF)
vizact.onkeydown(' ', pickChair)
Does anyone know how to do this, but using the joystick?
Thank you in advance.
Best regards,
Isabel
Old 02-09-2011, 09:35 PM
Picking works with the mouse but you could simulate mouse movements with the joystick and use picking or you could use joystick data in combination with the screenToWorld and viz.intersect commands to select an object. How do you want to control the pointer since you're navigating with the joystick?
writing joystick position to a data file Saz Vizard 3 12-17-2008 06:18 AM
Pick porblem with arrays shivanangel Vizard 3 08-27-2007 11:10 AM
Facetracking and Immersion Joystick Vygreif Vizard 1 01-25-2006 11:56 AM
