Old 05-09-2005, 01:55 AM
exhale exhale is offline
running multiple vizard scripts from python
This is what I want to accomplish:
A main.py file runs several vizard scripts one after another.
This command is used to run the vizard scripts:
execCommand = viz._BIN_PRIMARY + ' "' + filename + '" 0'
win32process.CreateProcess(None, execCommand,
None, None, 1, 0, None,
None, win32process.STARTUPINFO())
Now the problem is it runs several of the vizard scripts at the same time. I could not really find module descriptions for win32process .. Now my question is, is it possible to run a script, then wait till that process is over and then continue the main script?
EDIT: I've also been experimenting with spawnl(P_WAIT, execCommand) but when the first vizard script is launched and i quit the graphical window, it doesnt continue the original script. Apparently this is caused because my calling function was startscript, which seems to be implemented in vizard.. But either way i haven't got it to work .
greets,
Kevin
Old 05-09-2005, 05:35 AM
got it to work using:
os.system('c:\\Progra~1\\Vizard25\\bin\\winviz.exe c:\\Progra~1\\Vizard25\\experimenten\\Final\\a-01.py 0')
this is dynamically changed, but that's what it comes down to.
greets
