Old 11-06-2010, 03:26 PM
driechers driechers is offline
an object in motion does not stay in motion?
I am trying to work in a zero gravity environment I have the gravity set to zero but when I apply a force to my object it slows down and eventually stops. is there a way I can make an object in motion retain its velocity as if it were in outer space. I have been stuck on this for a while i tried changing the different physical properties of the object but it still slows down as if it were in an atmosphere.
fyi i am still using the trial version if that makes any difference
Old 11-08-2010, 09:02 AM
Take a look at the addThruster command on the following page:
http://www.worldviz.com/vizhelp/Forces.htm
Old 11-09-2010, 03:51 PM
cool thanks
how to hide 3D virtual object behind real object? Darkmax Vizard 3 05-29-2012 09:39 AM
Remove link and have object drop/collide? cgibb Vizard 6 03-02-2010 04:18 PM
