Old 10-31-2010, 02:08 PM
c4am95 c4am95 is offline
World Transformations
Hello. I'm using an HMD and intersense tracker. Code-wise, I use methods like "link.postTrans", etc. to apply virtual world transformations when using the HMD directly. However, I want to use the environment for testing as well, so I'm trying to find an easy way to apply world transformations without the tracker. It's surprisingly not as easy as I thought it would be. How could I, for example, rotate the entire world 180 degrees so that the camera is situated in the same position and now facing the other way, but the virtual subject it represents hasn't physically turned around?
Old 11-02-2010, 12:32 PM
You can link the viewpoint to a mouse/keyboard tracker and apply a link operator to that:
gallery = viz.addChild('gallery.ive')
import viztracker
tracker = viztracker.KeyboardMouse6DOF()
link = viz.link(tracker,viz.MainView)
link.postEuler([180,0,0])
Does this do what you want?
Old 11-07-2010, 11:53 AM
this could work. but how do you change the properties of viztracker? for example, if i only want movement in x and z (no flying), how do i reduce the degrees of freedom?
Old 11-08-2010, 09:10 AM
Does the following work for you?
import viztracker
fixedTracker = viz.addGroup()
link = viz.link(fixedTracker,viz.MainView)
def updateView():
	x,y,z = tracker.getPosition()
	fixedTracker.setPosition(x,1.8,z)
	fixedTracker.setEuler(tracker.getEuler())
vizact.ontimer(0,updateView)
Old 11-09-2010, 12:50 PM
yeah that works well. albeit, it made the eyeheight incredibly high for some reason. when i used instead:
fixedTracker.setPosition(x, 0, z)
it looked normal. bizarre?
why is time faster in my virtual world? billjarrold Vizard 1 11-24-2009 05:33 PM
What are the options for making a movie of a Vizard world? Karla Vizard 1 05-13-2008 10:56 AM
Pre/Post transformations pattie Vizard 5 10-02-2006 04:20 PM
General Questions about Vizard: World Viz dav Vizard 5 08-28-2006 03:44 PM
Avatar bone rotations respect to world MiamiTodd Vizard 3 02-14-2006 10:41 AM
