Thread Tools Rating: Thread Rating: 30 votes, 4.87 average. Display Modes
Old 09-13-2010, 04:00 PM
vOliver vOliver is offline
Problem with server Events
We're having a problem creating a simple server/client model where users log in and they can move around in the same world. We used the duck default model as avatars. I can paste the code in but lets see if i'm missing something obvious
The problem is with the events. Both server and client have the code
SEND = viznet.id('send')
and I then I do something in the client like
viznet.callback(SEND, update)
and this calls a function that updates the location of all the ducks. The code doesn't work because I never get something sent using the event id SEND for any of the clients. BUT, if I replace SEND with viz.NETWORK_EVENT, everything works as expected. But this is obviously problematic because it triggers on every event, and not all of the events are updates.
I tried printing out the value of UPDATE and its some crazy negative number, however it is the same number on both the server and client.
The relevant client code:
ducks = {}
UPDATE = viznet.id('update')
def sendData():
	global UPDATE
	viznet.client.sendAll(UPDATE, client=viz.getComputerName(), ori = viz.MainView.getEuler(), pos = viz.MainView.getPosition())
def update(e):
	print 'hello'
	if e.client != viz.getComputerName():
		try:
			ducks[e.client].setPosition(e.pos)
			ducks[e.client].setEuler(e.ori)
		except KeyError:
			ducks[e.client] = viz.add('duck.wrl')
viz.callback(SEND,update)
vizact.ontimer(0.1, sendData)
and Server code:
viznet.server.start(port_in=14950, port_out=14951)
ducks = {}
def Update(e):
	ducks[e.sender].setPosition(e.pos)
	ducks[e.sender].setEuler(e.ori)
viz.callback(UPDATE, Update)
def onStartClient(e):
	print '**Client Joined:', e.sender
	ducks[e.sender] = viz.add('duck.wrl')
viz.callback(viznet.CLIENT_CONNECT_EVENT, onStartClient)
def onStopClient(e):
	print '** Client left:', e.sender
	ducks[e.sender].remove()
viz.callback(viznet.CLIENT_DISCONNECT_EVENT, onStopClient)
Old 09-15-2010, 02:14 PM
Not sure whats going on in your code. Must be some bug somewhere that I'm not getting.
This example I worked up does what you want to do (I think):
IS_SERVER = True #change me to False for client
SERVER_NAME = 'DEV8.hq.worldviz.com' #for client, set to network name or IP of server
import viznet
OTHER_EVENT = viznet.id('OTHER_EVENT')
if IS_SERVER:
	viznet.server.start()
	def broadcast():
		viznet.server.send(UPDATE,message='Hello')
	def othersend():
		viznet.server.send(OTHER_EVENT,otherMessage='other event')
	vizact.ontimer(1, broadcast)
	vizact.ontimer(3, othersend)
	viznet.client.connect(SERVER_NAME)
	def onMyEvent(e):
		print 'Received event from server with message:',e.message
	viz.callback(UPDATE, onMyEvent)
	def otherEvent(e):
		print 'Received event from server with message:',e.otherMessage
	viz.callback(OTHER_EVENT, otherEvent)
Paul Elliott
WorldViz LLC
Old 09-15-2010, 02:21 PM
Looked at your code a little more...
I'm not seeing any call to viznet.client.send(SEND) or viznet.server.send(SEND) in your code. Thus the viznet.callback(SEND, update) won't get used. In your client code, change to viznet.callback(UPDATE, update) to receive the viznet.client.sendAll(UPDATE) calls the clients make.
Paul Elliott
WorldViz LLC
Client Server Networking Problem pattie Vizard 12 07-04-2013 09:11 AM
Linking problems with Live Character Frank Verberne Vizard 5 06-04-2008 11:42 AM
Floating license server problems jrodman Vizard 2 10-30-2006 10:39 AM
Intersense Server & 3d Max Hodge1620 Vizard 4 10-26-2005 01:39 PM
problem with female animations vmonkey Vizard 1 10-07-2005 10:36 AM
