Old 04-29-2010, 06:34 AM
guof6570969 guof6570969 is offline
Cool how to add texture to an object
Hi all,sorry to trouble you
this is my problem:
the code is :
myTex = viz.addTexture('lake3.jpg')
myScreen = viz.add('screen3.IVE' )#my model,contains a suface named "Plane01"
myScreen.setPosition(0,0, 60)
Plane = myScreen.getChild('Plane01')
Plane.rotate(1,0,0, 45)
import vizmat
matrix = vizmat.Transform()
matrix.setScale([1.5,1.5,1])
Plane.texture(myTex)
Plane.texmat(matrix)
but the result is :
the color of the model is only green
i think may be this is due to the Texture Coordinates
but what should i do now ?
I am a newer!
Old 04-30-2010, 03:25 PM
Make sure the object is exported with a texture applied. If no texture is applied, then the object does not have UVW coordinates.
In the future please use code tags when posting code. That will preserve any indentation and is easier to read.
Old 05-06-2010, 11:18 PM
thank you
Jeff
How to apply shader and render texture to an object whj Vizard 0 04-23-2010 01:23 PM
adding texture to each sub object dwaik Vizard 2 02-09-2010 02:05 AM
Applying texture or colour to an on-the-fly object tomo_the_third Vizard 1 06-22-2009 12:12 PM
Move texture from one object to another Johannes Vizard 2 02-09-2005 04:55 PM
