Old 03-30-2010, 04:13 PM
Adam Adam is offline
Plugin For Headtracking with webcam via FaceAPI
I would like to be able to be able to read the head position (x,y,z) and rotation values (y,p,r) from a webcam using FaceAPI and apply that data to my viewpoint in vizard and I am at a loss as to how to do this.
This video illustrates what I would like to be able to do. http://www.youtube.com/watch?v=uA8ZXPS6onk
I have found some google code projects that provide this position and orientation data via a socket but I have never worked with sockets before.
http://code.google.com/p/6dofstreamer/
I've attached an image of what the socket outputs.
How would I go about either accessing this data from the socket to update the viewpoint, or develop my own faceapi plugin to do this automatically.
Many thanks in advance to those more knowledgeable than myself.
Old 03-31-2010, 06:54 PM
Do you have more information about the FaceAPI socket protocol? Either way, you should be able to use the built-in Python socket module to receive data over the network.
Old 04-02-2010, 02:47 AM
JvdBosch JvdBosch is offline
Adam, I've sent you a private message.
Old 04-16-2010, 12:55 PM
I am trying to work that FACEAPI integration for headtracking via streaming position and orientation data from a socket and can't quite get it to work.
Could you look over my code and let me know what I may be doing wrong? The socket works and I can access the data, but I can't seem to get it to apply to my viewpoint.
-Adam
# Import Modules
from socket import *
import string
import math
# Set Global Variables
global host
global port
global buf
global addr
global HeadPos
global HeadRot
global pos
global euler
global view
# Run Vizard in Fullscreen
view = viz.MainView
viz.mouse(viz.OFF)
viz.mouse.setVisible(False)
# Load vrml and locate objects
viz.add('tut_ground.wrl')
pole = viz.add('pole.wrl')
pole.setPosition(0,0,4)
# Set the socket parameters
host = "localhost"
port = 29129
buf = 1024
addr = (host,port)
# Create socket and bind to address
UDPSock = socket(AF_INET,SOCK_DGRAM)
UDPSock.bind(addr)
# Receive messages
while 1:
	data,addr = UDPSock.recvfrom(buf)
	if not data:
		print "Client has exited!"
		break
		#print "\nReceived message '", data,"'"
		cp = str(data).split(' ')
		headposx = cp[0]
		headposx = float(headposx)
		headposy = cp[1]
		headposy = float(headposy)
		headposz = cp[2]
		headposz = float(headposz)
		headrotx = cp[3]
		headrotx = float(headrotx)
		headroty = cp[4]
		headroty = float(headroty)
		headrotz = cp[5]
		headrotz = float(headrotz)
		HeadPos = [headposx , headposy , headposz]
		print "\nHeadPos = ", HeadPos,"'"
		HeadRot = [headrotx , headroty , headrotz]
		print "\nHeadRot = ", HeadRot,"'"
		updateview()
# Close socket
UDPSock.close()
def updateview():
	viz.reset(viz.HEAD_ORI|viz.BODY_ORI|viz.HEAD_POS)
	#update orientation
	euler = view.getEuler(viz.Head_ORI)
	euler[0] += HeadRot[0]
	euler[1] += HeadRot[1]
	euler[2] += HeadRot[2]
	print "\nEuler = ", euler
	view.setEuler(euler,viz.Head_ORI)
	#update position
	pos = view.getPosition(viz.Head_POS)
	pos[0] += HeadPos[0]
	pos[1] += HeadPos[1]
	pos[2] += HeadPos[2]
	print "\nPosition = ", pos
	view.setPosition(pos[0],pos[1],pos[2])
vizact.ontimer(0,updateview)
Video Stream plugin Brett Lindberg Plug-in development 7 08-18-2009 04:06 PM
Howto debug a custom plugin? reedev Plug-in development 3 04-23-2009 03:16 PM
problems with webcam plug-in v-clizzin Plug-in development 2 01-25-2008 04:06 PM
