Old 02-28-2010, 05:33 PM
cgibb cgibb is offline
Remove link and have object drop/collide?
Is there an easy way to remove a link, but then have the object drop and collide with other objects?
For example: a user picks up an object, a link is created with viz.grab(foo,bar), and when they right click, the link is removed with link.remove().
Is it possible for that object to fall to the ground/collide with another object (table, floor, etc.) without manually setting the position? Currently, it floats in mid-air.
Thanks in advance!
Old 03-01-2010, 12:40 AM
dwaik dwaik is offline
Hello;
am facing that problem too and i have nother one maybe you could help me,
i need to know the object under the mouse, so that i can grab it, any idea?
thanks in advance
Old 03-01-2010, 06:12 AM
Originally Posted by dwaik View Post
Hello;
thanks in advance
Please don't hijack this thread. Thanks.
Old 03-01-2010, 09:54 AM
You will need to enable the physics engine in order to have collisions between objects and the effects of gravity. The Vizard docs explain how to add physics.
Old 03-01-2010, 08:52 PM
Thanks, Jeff. That worked when an object hits the ground, but what about other objects in my base model? For example, if I have a room with a built in counter, is there a way for the 'dropped' object to collide with that?
Here's a bit of what I'm working with:
viz.phys.enable()
room.collidePlane()
if link and checkobject(object) == 'foobar':
	foobar.collideBox(1,2.5,1) #hits the ground
	link.remove()
The object (foobar) in this situation will drop right through the counter to the ground.
Thanks again.
Old 03-02-2010, 03:42 PM
Have you tried applying a collide mesh to the room model?
room.collideMesh()
room.disable( viz.DYNAMICS )
Old 03-02-2010, 04:18 PM
room.collideMesh()
This worked great in combination with collideBox()
Thanks again!
