Old 12-01-2004, 10:59 AM
spacefarer spacefarer is offline
viewpoint movement
Hi!
I would like to move my view point smoothly 1m per pressing an button and to rotate it 90 degrees if I press another button, and wrote a program shown as below.
But there are two major problems.
1. The viewpoint does'nt rotate exactly 90 degrees (like 89.999925...). I want it to rotate just 90 degrees evey time.
2. If you press the button during the view point is changing, the view point moves 1m or rotates 90 degrees from the moment.
I want the [x,y,z] of the view point to be always integer when the view point stops.
I would appreciate your suggestions.
Thank you.
def mykeyboard(key):
pos = viz.get(viz.HEAD_POS)
tx = pos[0]
ty = pos[1]
tz = pos[2]
trans = viz.get(viz.BODY_LOOK)
# Translate_Forward
if viz.iskeydown(viz.KEY_UP):
tx = tx + trans[0]
ty = ty + trans[1]
tz = tz + trans[2]
view.goto(tx,ty,tz,1,viz.TIME)
# Yaw_Right
elif viz.iskeydown('6'):
viz.starttimer(1, 0.01,89)
def mytimer(num):
if num == 2: #Yaw-Right
view.rotate(0,1,0,1,viz.BODY_ORI,viz.RELATIVE_LOCA L)
Old 12-01-2004, 12:35 PM
I wrote the following sample script that should fix your problems. I use the viewpoints built-in animation engines to translate and rotate. When they are finished I translate/rotate them to the final value just to be sure they are exact. Also, when I calculate where to move/turn, I round the values to integers. Also, I check if the viewpoint is currently being animated when a key is pressed.
#Add a ground
viz.add('tut_ground.wrl')
#Get main viewpoint object
#Create a variable that will tell whether viewpoing is currently moving/turning
view.animating = 0
#Variable that holds current destination value
final = [0,0,0,0]
def onkeydown(key):
	if key == viz.KEY_UP:
		#Make sure view is not animating
		if not view.animating:
			pos = view.get(viz.HEAD_POS)
			trans = view.get(viz.BODY_LOOK)
			#Round values to nearest integer
			final[0] = int(round(pos[0] + trans[0]))
			final[1] = int(round(pos[1] + trans[1]))
			final[2] = int(round(pos[2] + trans[2]))
			#Start animating viewpoint
			view.goto(final,1,viz.TIME)
			view.animating = 1
	elif key == '6':
			#Compute rotation of turning body 90 degrees to right
			xform = viz.Transform(view.get(viz.BODY_MAT))
			xform.postRot(0,1,0,90)
			rot = xform.getRot()
			final[0] = int(round(rot[0]))
			final[1] = int(round(rot[1]))
			final[2] = int(round(rot[2]))
			final[3] = int(round(rot[3]))
			view.spinmask(viz.BODY_ORI) #Spin the body orientation
			view.spinto(final,45) #Spin with speed of 45 deg/sec
			view.animating = 1
def onstop(object, type):
	if type == viz.MOVE:
		#Viewpoint is done moving, translate it to the final value just to be sure
		view.translate(final)
		view.animating = 0
	elif type == viz.SPIN:
		#Viewpoint is done spinning, rotate it to the final value just to be sure
		view.rotate(final,viz.BODY_ORI)
		view.animating = 0
view.callback(viz.STOP_EVENT,onstop)
Old 12-01-2004, 05:24 PM
Thank you very much.
It worked!
But I have a new problem.
I actually want 6DOF viewpoint movement.
When I applied the yaw rotation program to pitch and roll, the visual scene is sometimes distorted because I think my matrix is simply wrong.
Could you also tell me pitch and roll cases?
Old 12-01-2004, 08:29 PM
Once you begin to introduce pitch and roll, you cannot use integers to represent the Axis-Angle rotation. I've modified the script so that it doesn't round the rotation values. I also changed the rotation code so that it performs a pre-rotation instead of a post-rotation. This makes each rotation relative to the current reference frame.
If you still need the extra precision you could round the angle value of the rotation to an integer. You could also round the axis values of the rotation, but you need to make sure that you don't round the value when it is close to ±0.57735
#Add a ground
view.animating = 0
final = [0,0,0,0]
def rotateview(x,y,z,angle):
		xform.preRot(x,y,z,angle)
		final[:] = xform.getRot()[:]
		view.spinto(final,2,viz.TIME) #Spin for 2 seconds
		view.animating = 1
def onkeydown(key):
			view.animating = 1
	elif key == '6': #yaw right
		rotateview(0,1,0,90)
	elif key == '4': #yaw left
		rotateview(0,1,0,-90)
	elif key == '8': #pitch up
		rotateview(1,0,0,-90)
	elif key == '2': #pitch down
		rotateview(1,0,0,90)
	elif key == '9': #roll right
		rotateview(0,0,1,-90)
	elif key == '7': #roll left
		rotateview(0,0,1,90)
		view.animating = 0
		view.animating = 0
Old 12-02-2004, 07:23 AM
Thank you so much again.
I've tried your modified program and each axis is up to only 10^-7 order off from the exact value. So I think I just round the values when I record the axes data.
