Old 02-10-2010, 01:38 PM
JimC JimC is offline
Small doc error & clarification
In the docs for viz.phys.intersectLine(), the last argument is called 'listAll'; 'all' is correct.
On this page and for viz.phys.intersect() it states that the function returns a VizIntersect object; if 'all' is True, it returns a list of VizIntersects.
Old 02-10-2010, 02:16 PM
Unhappy
viz.phys.intersectLine() doesn't seem to work with all=True, anyway; I never get more than one intersection. viz.intersect() (sorry, mis-typed it in the original post) works fine, though.
Old 02-11-2010, 07:25 AM
Doc problems for those who like keyword args...
It seems that the argument names in the docs often don't match those in the code; that is, the docs make it look as though you can pass arguments in keyword form (which I think makes for more readable code), but it often doesn't work that way using the names as given. Of course, I can always look at the source...
Old 02-12-2010, 10:36 AM
Thanks for the note the about the incorrect argument name. If you notice something like that again, please mention it and we'll make the correction.
Here's an example that uses all = True with viz.phys.intersectLine() to turn intersected nodes.
box = viz.add('box.wrl', pos = [0,1,5])
shape1 = box.collideBox()
box2 = viz.add('box.wrl', pos = [0,1,7])
shape2 = box2.collideBox()
def FireLine():
	line = viz.MainWindow.screenToWorld(viz.mouse.getPosition()+[0])
	dir = viz.Vector(line.dir)
	dir.setLength(200)
	begin = line.begin
	end = line.begin + dir
	info = viz.phys.intersectLine(begin,end, all = True)
	for i in info:
		i.object.color(viz.BLUE)
vizact.onmousedown(viz.MOUSEBUTTON_LEFT,FireLine)
viz.mouse(viz.OFF)
Can you post an example where it did notwork for you?
Old 02-16-2010, 07:42 AM
Actually, I think it's just me not realizing that viz.phys.intersectLine() and viz.intersect() behave differently when all==True. viz.intersectLine() tells you which objects are intersected (one intersection/object), whereas viz.intersect() gives you every intersection point (e.g, where the line intersects front _and_ back faces of the same object)--which is the behavior I was looking for.
I guess the docs could be a bit more explicit about that.
PPT movement in small area durf Precision Position Tracker (PPT) 1 02-26-2009 12:02 PM
PPT movement in small area using vizard 3.0 durf Vizard 3 02-24-2009 09:34 AM
Small Vizard programming Jobs? realvision Announcements 0 03-17-2008 08:53 AM
Tracking a small space aaThomas Precision Position Tracker (PPT) 3 05-31-2007 10:59 AM
Full screen window changes to small window tacbob Vizard 1 04-04-2007 09:30 AM
