Old 12-29-2009, 03:43 PM
moneim230 moneim230 is offline
Question 2 sliders from 1 joystick (Logitech G25)
Hello all,
i'm using Logitech G25 steering wheel in my code and i have a problem.
i have all the signals from it except the clutch pedal
when i use "vizjoy.getSliderCount()" it returns 2 which mean i have 2 sliders
but when i print the value of the slider i get postive values from the gas pedal and negative values from the breaks pedal...Does this mean that the gas and the breaks pedal are one slider ??? (+ve for breaks , -ve for gas)
if that is right...how to get the 2nd slider value ?
Old 12-29-2009, 05:47 PM
Post signals
here is a code i created to get signals from the G25 steering wheel:
import vizjoy
G25=vizjoy.add()
def button(state):
	state = G25.getButtonState()
	print 'Button State = ',state
def joymove(x):
	x=G25.getPosition()
	print 'Position = ',x
def twistvalue(x):
	x=G25.getTwist()
	print 'Twist = ',x
def slidervalue(x):
	x=G25.getSlider()
	print 'Slider =',x
def hatangle(x):
	x=G25.getHat()
	print 'Hat=',x
print 'Joystick name = ',G25.getName()
print 'Slider count = ',G25.getSliderCount()
print 'Button count = ',G25.getButtonCount()
print 'Hat count = ',G25.getHatCount()
viz.callback(vizjoy.BUTTONDOWN_EVENT,button)
viz.callback(vizjoy.MOVE_EVENT,joymove)
viz.callback(vizjoy.TWIST_EVENT,twistvalue)
viz.callback(vizjoy.SLIDER_EVENT,slidervalue)
viz.callback(vizjoy.HAT_EVENT,hatangle)
Old 01-04-2010, 12:56 PM
If you use the clutch pedal do you notice a change in the Z value when you print the position?
def showJoyPosition():
	print 'position:  ',joy.getPosition()
vizact.ontimer(0.1, showJoyPosition)
Old 01-07-2010, 12:47 PM
no Z value does not change
Only the value of X changes (+ve for steering right , -ve for steering left)
Y & Z are always zero
Old 01-11-2010, 03:56 PM
Are there different modes that you can put the G25 steering wheel in?
Old 01-14-2010, 05:01 AM
it works in 2 modes:
the first is manual gearing (6 speeds + reverse)
the second is sequential (step up , step down)
i use the first one but this has nothing to do with the clutch signal
changing the gain of a joystick during a program Saz Vizard 4 06-25-2009 04:49 AM
writing joystick position to a data file Saz Vizard 3 12-17-2008 06:18 AM
Joystick Navigation Vinicius Lima Vizard 7 10-23-2007 11:42 AM
Facetracking and Immersion Joystick Vygreif Vizard 1 01-25-2006 11:56 AM
Basic Joystick Navigation Question Plasma Vizard 2 01-29-2004 08:08 PM
